Microphone is not working
    I am trying to record voice overs for videos I am making with a program called Pinnacle Studios 14. It's a little outdated but it gets the job done well. I am also running Windows 8 on a new computer. I am also using (or trying to use) a Logitech USB headset/microphone. The problem I am having is that when I try to select a microphone for the voice over it does not appear on the list of microphones I can use. I checked the Audio Settings under Control Panel and my computer recognizes that the headset is plugged in. I am not sure if it is the microphone that is not compatible with Windows 8 or its the Program that is not compatible with the microphone. Should I buy a new microphone? Should I get the upgraded version of Pinnacle? Help please.
    Harrisonburg, Va.
    I have the same headset.
    It works good for me.
Headset Microphone not working
Hello Eightforums. Firstly, my problem is that my headset microphone is not working correctly. As my laptop (Lenovo g505s) only has 1 audio jack, but my headset has 2 cables (green and pink), i bought a 3.5mm headset splitter adapter that splits audio output to 3.5m headphone and 3.5 mic jack....
Hi, I have a Dell Dimension running Win 8.1 pro. Recently my microphone has stopped working. I have looked at other threads and none have helped. My mic does work with other computers but no with mine. When I tried to record my voice on many apps (Skype, sound recorder) but no luck. When I pull the...
I have a Creative Fatal1ty Gaming Headset , the audio work's but I cannot get the mic to work. I have a Creative soundblaster 5.1 live soundcard and a abit fatal1ty fp-in9 sli m/b. Audio works on both soundcard and on-board sound on the m/b , but not the mic .... I know some basics to...
Soundblaster card & microphone on headset not working
Hallo, The microphone on this non-brand headset isn't working due to the microphone not showing up under the recording devices. Audio is working for the headset (and anything else that I plug in ), but not the microphone. The green bars do not go up in the audio manager either when I test the...
Microphone not working after installing W@indows 8 Pro wmc
I have a HP dv2519tu laptop. I have clean installed Windows 8 Pro wmc last week. But after installtion my default microphone is not working. I have checked everything like drivers but still there is no solution.Please help me friends as I am getting problems. Thanks in advance..Arvin
Built-In Microphone Not Working after Upgrade
Good evening everyone, I recently upgraded my HP Touchsmart IQ500 from Vista Home Premium to Windows 8 Pro. Aside from the lack of a media center or otherwise out-of-the-box-inability for DVD playback I've been enjoying the change. I solved the DVD problem with VLC, but I cannot figure out how...
Drivers & Hardware
8 microphone
microphone not working
