Headphone Jack Not Working
    I updated to Windows 8 today, and everything seemed to be going well until I tried playing music through my headphones. They worked fine on my iPhone, but once I plugged them into my laptop, no sound came out.
    Pictures:
    I ran windows updates today.
    It looks like, with the "High Definition Audio Device" that you only have the basic function Windows installed sound drivers.
    Try installing the PC Vendor's sound driver. Same way for HDMI install the Video Card vendor's drivers.
    Harrisonburg, Va.
    Hello,
    Is your headset USB or straight plug-in ?
    Mine is USB.
    I plugged it in & the tiny icon for discovering new hardware appeared in the Notification Area.
    Things went smoothly & the headset was installed & works.
    I made it Default for sounds.
    Here are a couple of screen-shots---
    I have a similar problem whereby I have to search at too great a length to get the sound to the speakers to automatically cancel (mute) when I plug the headphones in and then do the reverse when I unplug them. When in WMP all is fine, but on any other application - say Youtube, there is only sound through the speakers unless I disable them. The headphones then work! But now I am searching as to why, when I enabled the speakers, that it didn't go back to where it was before!? What on earth is wrong with Win 8 that it messes up ALL of the chosen settings that were automatic beforehand!? All of the drivers are up to date and working, just the auto settings, which I can't find.
    First, make sure you are using the PC Vendor's sound drivers. Non Vendor drivers or even the generic basic function Windows installed HD Codec may not work or work correctly.
    Youtube uses Adobe Flash and there have been many problems with that. WMP uses the basic PC sound functions.
    Thanks, but it is just sound. When one plugs in the headphones or whatever in the same plug, the sound goes off at the speakers and onto the headphones - normally! but not any more. This surely can't be flash? All of my other programmes for sound say 'drivers installed and up to date' etc. I do remember a long time ago, a tick-box or similar which asked what I wanted the sound to do when I plugged the headphones in, but I can't remember where that is. Loading W8 shouldn't have had any effect on anything else...
    If you have RealTek, you should have a RealTek HD Audio Manager panel that will give you that option (if available). It is located in the Control Panel/Hardware and Sound.
    dehradun
    window 8 pro (64bit)+ window 7 ultimate (32bits)
    I have the same problem.speakers are working fine but there is no sound in headphone.I have installed sound drivers and graphic card drivers in window 8.But in window 7,headphone is working fine
Windows Won't recognize Combo Mic/Headphone Jack
Hey guys, I've been looking everywhere for a solution to this: Headphones Working Fine, Mics aren't...But totally no luck. I can see that a lot of people are having this problem and posting it on various forums, without any valid solutions or workarounds. The Problem: Asus Laptop with Windows 8.1...
headphone jack says it's unplugged in windows 8.1
I have read a number of threads on this issue. My HP running windows 8.1 with IDT High Definition Audio CODEC consistently tells me that my headphones are unplugged in both the front and back audio ports of my desktop. I thought getting windows 8.1 on my new desktop would enable me to have audio....
Audio Input Jack on Computer Not Working
My Dad used to use the laptop that me and my Mom share, and he did something to the settings on the computer (I don't know what, or else I would have fixed it myself.) which allow you to use a USB mic, and he disabled the microphone jack on the computer. I really want to find out how to change...
No sound from headphone jack
title says it, i downloaded the most recent version of the realteck drivers from toshibas site and i have no sound when plugging in headphones. :geek:
Messed up headphone audio; want to check headphone jack
3.5mm jack problem
Hello, Newbie here so hi! I have a very strange problem.. I have an Asus x102ba notebook. I normally have it connected to my TV via hdmi cable to view on a bigger screen. I have a 3.1 surround system which I connect to the laptop via the 3.5mm headphone jack. As soon as I connect all this...
Windows 8 Headphone Jack
This seems to be a pretty common problem. I'm working on my friends computer, because his headphone jack isn't working. He has an Acer Aspire M, with a third-gen i5, 6GB DDR3, Windows 8 64bit, and a Realtek card. He had been using headphones in the side jack, and they were working fine, but...
