Headphone Jack Not Working
Tyluur
I updated to Windows 8 today, and everything seemed to be going well until I tried playing music through my headphones. They worked fine on my iPhone, but once I plugged them into my laptop, no sound came out.
Pictures:
I ran windows updates today.
It looks like, with the "High Definition Audio Device" that you only have the basic function Windows installed sound drivers.
Try installing the PC Vendor's sound driver. Same way for HDMI install the Video Card vendor's drivers.
Hello,
Is your headset USB or straight plug-in ?
Mine is USB.
I plugged it in & the tiny icon for discovering new hardware appeared in the Notification Area.
Things went smoothly & the headset was installed & works.
I made it Default for sounds.
Here are a couple of screen-shots---
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
I have a similar problem whereby I have to search at too great a length to get the sound to the speakers to automatically cancel (mute) when I plug the headphones in and then do the reverse when I unplug them. When in WMP all is fine, but on any other application - say Youtube, there is only sound through the speakers unless I disable them. The headphones then work! But now I am searching as to why, when I enabled the speakers, that it didn't go back to where it was before!? What on earth is wrong with Win 8 that it messes up ALL of the chosen settings that were automatic beforehand!? All of the drivers are up to date and working, just the auto settings, which I can't find.
First, make sure you are using the PC Vendor's sound drivers. Non Vendor drivers or even the generic basic function Windows installed HD Codec may not work or work correctly.
Youtube uses Adobe Flash and there have been many problems with that. WMP uses the basic PC sound functions.
Thanks, but it is just sound. When one plugs in the headphones or whatever in the same plug, the sound goes off at the speakers and onto the headphones - normally! but not any more. This surely can't be flash? All of my other programmes for sound say 'drivers installed and up to date' etc. I do remember a long time ago, a tick-box or similar which asked what I wanted the sound to do when I plugged the headphones in, but I can't remember where that is. Loading W8 shouldn't have had any effect on anything else...
If you have RealTek, you should have a RealTek HD Audio Manager panel that will give you that option (if available). It is located in the Control Panel/Hardware and Sound.
I have the same problem.speakers are working fine but there is no sound in headphone.I have installed sound drivers and graphic card drivers in window 8.But in window 7,headphone is working fine
    window 8 pro (64bit)+ window 7 ultimate (32bits)
    AMD Athlon II X4 635
    Asus M5A78L-MLE
    4.00 GB ram ddr3
    power color 7750
    1600 X 900
    500 gb hard disk (seagate)
    Necola NPS-1004ST (450 W)
    opera
    avg
