Option to "not monitor mic"
    windows 8 64bit
    Realtek When I use the Mic in the front slot, I can hear myself through the speakers. I would like to disable this but there is no option for "do not monitor mic" through playback options. Is there a registry setting I could adjust or another solution?
    That is a bane of everyone that uses a mic. That is the reason many go to a headset with a mic as that minimizes feedback from the mic.
    The other option is to turn the speaker volume to off.
Removing "Format" option from context menu for drives!
I want to remove the option of “Format” from context menu for drives. Could I get some help on how to do this?
Enabling "Startup Apps" option in the CACS window
Hi I have Windows 8.1 Update Enterprise 64-bit. I noticed that, in the "Change Action Center settings" window, the "Startup Apps" option is disabled. How come? How do I enable it? What is the purpose of this option?Thanks Bye
Performance & Maintenance
No "uefi firmware settings" option on asrock z77 extreme 4
I cannot seem to access the bios at all with windows 8.1 and my gtx 780 ti. When I connect the hdmi to my gtx 670, I can see the bios screen and can change the config but with the hdmi in my 780 ti I get a black screen until the dual boot windows selection. I've disable fast boot and have no idea...
(Win8.1) Refresh Install option "some files are missing"
Hi guys, what do I do if the refresh install on W8.1 says that I'm missing files? I installed W8 from a retail disc and upgraded to 8.1 via Windows Update. I can't use the W8 disc, it says invalid media. Do I just follow the steps shown on the tutorial here? Thanks.
"Custom" option missing from "Search again in"
Even though the tutorial on this forum says there should be a custom option, I don't seem to have it. 37375 Any thoughts on how can I bring it back? P.S. Does anyone know what that "winrt--{***}-" folder is?
Option traders here -- CBOE to offer "Mini Options"
Hi there I know we have some Market traders here If you've ever looked at OPTIONS trading but been put off because of the cost ( 1 contract = 100 shares) the CBOE from today is starting to offer "Mini Option" contracts --these are for multiples of 10 Shares. This makes it easier for those...
Chillout Room
No "remove old windows installations" option in Disk Cleanup.
What's a quick and easy way to remove windows.old since Disk Cleanup seems to be missing the option to do so in Windows 8 Consumer Preview. Edit: I gave myself permissions via CMD which failed(Every file access denied, even in an admin CMD), so I tried one last time to run a Disk Cleanup and...
