Static on both my Xonar DG and Nvidia GTX460, need help.
  1. #11
    I tried all of that, still nothing, not sure what it could be, or why and how both sound sources are effected.
    I disabled the on board long ago when I got the Xonar, still says it disabled.
  2. #12
    My Xonar D2 works fine using the drivers from the Asus site. Never had a problem with it, in fact I tested several different sound cards and sent them all back but this one.
    If you want to see flaky problems try using a creative card.
    I really have no idea where this static might be coming from but power supply's have been known to make a buzzing noise from time to time.
  3. #13
    You mean the power supply effecting the headphones speakers somehow? Anything I would be able to do to test for that?
Page 2 of 2 FirstFirst 12
BSOD after waking up from sleep mode related to Xonar card
I did a clean install of Windows 8.1 recently. Now when my computer wakes up from sleep I receive a DRIVER_IRQ_NOT LESS_OR_EQUAL BSOD related to cmudaxp.sys, which I've discovered is related to my Asus Xonar Essence STX sound card. I am running the Windows 8.1 beta drivers directly from Asus's...
BSOD Crashes and Debugging
Nvidia GTX460 and P8Z77V Deluxe No POST
I have a bit of a strange problem here, my main video is run from the Gigabyte Nvidia GTX460 1GB OC, it has worked pretty much OK since I had it, after installing some later versions of the Nvidia drivers (310+) I had the odd driver crash where the screen recovers, not too much of an issue. ...
Graphic Cards
Constant buzzing sound with Asus xonar d2x
Hey, yesterday I went from windows 7 to windows 8, everytime I close a game or a program with sound, this buzzing noise comes, and it wont stop until I restart my PC. Might be worth mentioning that the drivers are beta drivers, but they have been since 2012, so the shouldnt be a problem. And yes I...
New AMD Radeon HD 7970 card install, now no ASUS Xonar DS?
Just got my first AMD card in years (maybe around ~5 years), I installed the latest driver from AMD without issues (13.10) then I installed the driver for the ASUS Xonar DS, the driver installed fine, but the sound card is not being detected as the primary Sound Device for Windows, it appears with...
Xonar DX Won't Work After Computer Wakes Up
So why this problem just started, I don't know. Windows 8 64 pro with a Xonar DX sound card. Works fine on start up or restart, but wont work after waking from sleep mode. Devise management says it's working fine but ITunes or Pandora, (or anything for that matter) won't play. Checking...
Static & Dynamic IP
My bro changed our IP to dynamic and I want it static although after I enter IP , Subnet and Gateway , I press save , and nothing happens I'll give you soem screenshots so that you'll be able to help , for example tell me that this option should be like this in order for it to save. Thanks for...
Network & Sharing
Asus Xonar D2X
Greetings all, I installed the Win8 Enterprise Eval 64-bit, but quickly went back to Win7 because of sound drivers. I turned on Test Mode and disabled Driver Enforcement and tried both the Asus drivers and Brainbit drivers but couldn't get a working control panel but did get several blue...
