Switch Between Headphones and SPeakers no auto
    Hey back In windows 7, When I plugged in a pair of headphones the sound automatically changed to the what it was last time I plugged them in.
    And when I unplugged them, the sound switched back to speakers...
    In windows 8 (not pro version) when I plug in headphones, the sound doesn't go back to 8/100 like I set it last time I plugged them in. It will stay at 100/100 or whatever the speakers were set at.
    Also when I unplug them, the sound will not change back to the speaker level, it'll stay down at whatever it was at.
    I thought it'd be alright, but now it's getting really annoying.
    Every time i plug the headphones in, I have to put the sound down to not blow out my ears. And when I unplug, I have to put sound up...
    Anyone know why this is so? I can't recall if my old Windows 8 Pro had the auto sound change or not.
    I've never seen that, but if you had it before its a function of the sound driver or possibly any add-on sound application (e.g. the Beats Audio). Beats Audio is not the actual sound device, its just a HP add on to the sound similar to what Creative does with the SoundBlaster Audigy MB software enhancements.
    Windows 8 Pro
    I am running Windows 8 Pro, and am only using the Windows provided drivers and when I plug in headphones it does go back to its previous headphone audio setting, so it is either the fact that you are not running pro (which seems like an odd thing to be excluded from the non-pro) or that there is a setting some where that will allow you to change that. I looked through the sound settings but did not find anything.
    You could try uninstalling the audio driver and running Windows update to get the Windows provided may lose some functionality however...
Win 8.1 No speakers or headphones are plugged in (Realtek)
Dear all, I've been facing an issue with my sound lately (potentially linked to the win 8.1 update - as seems to be the case of a lot of people); I'm unable to get my sound to work, and I'm getting the following error message: "No speakers or headphones are plugged in". I've been trying out a...
'No speakers or headphones plugged in - win8
Hi friends, I am using Windows 8. I am facing an issue with my sound all on a sudden. The volume icon on the task bar has a red cross on it. When I hover on that it says 'No speakers or headphones plugged in' (attachment-1). When I click on the icon I get a screen like attachment-2 which...
sound gone after switching speakers to headphones!
Hello, this is really strange. Whenever I unplug the speakers jack and plug in the headphones, the sound stops! I have to restart the application or run another one and then the sound is back. This is really silly and takes time especially when you need to restart some game. Why does it happen and...
Hi! Sorry if this topic already exist, but i think it is little different. I had this problem, i went to BIOS and enabled sound, but, when i turned on computer there was sound, but it was show as headphones, and speakers aren't plugged in. Actually is opposite, headphones aren't plugged in, but...
My Headphones will work but speakers wont.
I recently upgraded to windows 8 pro 32 bit. For a month there were no problems. But one sunday afternoon i was watching some movie on my laptop and suddenly the speakers stopped working. I restarted it, but to no avail. However my headphones still work, and so do external speakers work. I...
Speakers and Headphones for Logitech G110
I have 2 speakers plugged in on m motherboards audio jacks, and my G110 keyboard has sound card of it's own built in. I was wondering if there was any way to set it up the way I want it, or something similar to it. The keyboard has a headphone mute button of its own. So I was thinking that I...
Audio coming from both Headphones and Speakers from my dell 15R.
