Virtual Sound Card?
    Virtual Sound Card?
    I just bought new speakers and want more boom out of the sub so installed SRS audio sandbox. it tells me on startup however that there is no compatible sound card to use. I am running windows 8 on a laptop so I cannot install a sound card. is there any way I can emulate a sound card so I can use SRS? thanks in advance
    You have a built in sound device, such as RealTek, IDT, etc. Which apparently works as you just want louder volume and more bass. Much of that is the speakers themselves and not the PC audio. I have RealTek built in audio in my PC and I have a 2.1 speaker system connected and sometimes I get too much bass.
    Pleas fill in the My System Specs so we have specifics. Without it we can only guess or offer general suggestions.
Virtual Sound Card?
Best Sound Card for Beats Studio
Hi, I am considering to make a Editing PC to make Dub step on, I am definitely getting a pair of Beats Studio Headphones, I wondered what will be the best sound card(I am only using 1 pair of headphones)
Sound Card not working
Irql_Driver_No_Less_Or_Equal (cmudaxp.sys) -- Sound Card?
EDIT: I fixed it by uninstalling the xonar dg drivers, shutting down, then removing the sound card. Why did I buy this thing anyways.. the onboard sound sounds just as good. -All Windows 8 updates installed -All drivers I could possibly think of to install, installed This all started when I...
BSOD Crashes and Debugging
Sound Card Recommendations
Hi, I am looking for a decent quality sound card for the rig that is detailed in my profile. I have a budget of around 60 I was wondering if anyone on here can recommend a good sound card or if anyone has any experiences with any? Thanks for your help.
Sound Card Issues
Every 5 days or so, my sound card will have a bad day, and all noise coming through my headset will be distorted and static-like. Usually restarting my computer will fix it, but today it stopped working altogether. I check the computer, and it says that no headphones or audio are plugged in. I...
Sabrent SBT-SP6C sound card
By any chance anybody has this card and figured out how to get this card to work under Windows 8? There's no W8 driver and W7 driver doesn't work.
Drivers & Hardware
No sound on LeadtekTV card on windows 8
Hi all. I have an old TV tuner, Leadtek TV2000XP Deluxe and the WinFast PVR2 tv software. System is Windows 8 Pro. As I said, the card is old and last drivers were for Vista. But those drivers worked perfectly with Windows 7. Now in Windows 8, I instaleed the same drivers and TV Card is working...
