empty recycle bin wav
    Harrisonburg, Va.
    I use the attached .wav as Empty Recycle Bin sound.
    It makes me chuckle.
    test it in Windows Media Player.
Getting back 'Empty Recycle Bin' Context Menu On Recycle Bin
Hey! I'm on Windows 8 Pro RTM and I accidentally removed my Empty Recycle Bin option from Recycle Bin context menu while playing around with context menu editing tool (Windows 8 Manager). I cannot to system restore because I installed many things, etc. which would be hassle to sort out. Could...
Recycle bin empty icon
In my windows 8.1 laptop, when I empty the recycle bin, the desktop icon does not refresh to the empty trashcan icon. How do I fix this bug in 8.1?
Recycle Bin - Empty in Windows 8
How to Empty Recycle Bin in Windows 8 and 8.1 The Recycle Bin is a temporary storage place for deleted files. When you delete a file or folder on your PC, it doesn't get permanently deleted—it goes to the Recycle Bin. This is good because if you ever change your mind and decide you need a...
recycle bin icons full/empty won't refresh automatically
Hello, My recycle bin full/empty icons won't refresh automatically. I need to press F-5 key to refresh them. I have tried lots of ways to fix it. I think it may have something to do with the icon cache, not sure though.
Desktop freezes when I empty Recycle Bin.
When I right click the Recycle Bin and click Empty Recycle Bin, the desktop freezes: the desktop become unclickable; if I click anywhere on the desktop, it just gives me a "ding" sound. Everything else works fine, like icons on the dock is clickable, I can go to start and open an app etc. ...
Folders are not empty but are shown as empty
Hello, I have an external hard and the folders in it are shown empty while they are full, but the folder inside them are shown correctly. I attached 2 images, 1045910460 Is it possible that virus cause this problem? It's actually impossible cause I have KIS2013 and it is updated. ...
