Windows 8 and hardware acceleration for sound cards ?
    windows 8 pro x64
    Does windows 8 offer hardware acceleration for sound processing in sound cards ? Or sounds are processed mainly via cpu ? I found a link claiming that accelaration does exist Windows 8 brings back the direct Audio Hardware Acceleration [just like old times - XP]
    Vista/Windows 7 sound drivers work in Windows 8. I have my RealTek plus my recording studio sound devices and all are working properly with Windows 7 drivers.
    There was a change in the way some sound functions were handled between XP and Vista/Win 7 and the reason XP drivers do not work or work correctly in Vista/Win7 (and Win 8).
    But, I have not noticed any difference in sound quality between XP and Vista/Win 7 with my recording studio hardware and to be truthful, the current technology RealTek sounds better than the SoundBlaster Audigy sound card I was using in Win XP.
    Windows 8 Ent
    The default sound drivers (the generic ones) that come with a freshly installed windows 8 are probably the best. The truth is that audio drivers haven't changed much in the last 20 years. Underneath it is all the same software, it's just repackaged with new layers to interact with kernel timers.
    By the way, accelerated audio is a joke. It never existed. I call it phantom technology. All they did was put the audio service as the highest priority right behind video, so it was a way to deliberately hobble audio so they could sell you a card that had a 1 instead of a 0 in its settings so it could bus-master, or come close to real time priority by turning on certain timing channel features which were already present from day one to begin with on every audio card.
    If anyone can give me a detailed whitepaper explaining exactly what audio accelearation is and how it worked with the hardware I will admit I am wrong, but I don't think I am from my research.
Two sound cards listed in Device Manager
Need help with multiple sound cards with 2.1 setup
Hello, I have an ASUS laptop integrated into my Bedroom Theater and 2.1 sound system. Currently I have an Audioquest Dragonfly DAC plugged into the USB 2.0 port from there the 1 stereo output of the Dragonfly heads over to a spliter after that one end goes to an amp for the main speakers and the...
Sound available only after scanning for new hardware
Hi there I have this new ASUS S400 vivobook and since day 1 there is no sound coming out of the speakers when they are not used for 5 min or so. I have tried the following actions one at a time but without fixing the problem: Updating "audio inputs and outputs", "sound, video and game...
Does anyone know how to turn off the hardware acceleration?
Does anyone know how to turn off the hardware acceleration? I tried doing it the way you are supposed to do it in Windows 7, but the tab in the control panel isn't there. Anyone know how to do this? Also I'm sorry if I posted this in the wrong place.
Graphic Cards
Planescape and hardware acceleration
Hello Eight Forum. I recently bought a new laptop to replace my aging desktop. So I've spent the past week getting in working order. (Ripping out the pre-installed software, getting avast/spybot/malwarebytes on it, etc.) After that I'm now ready to install some of my old games. I decided to...
Windows hardware insert.wav sound keeps going off
Whenever I am using my PC, the Windows hardware insert.wav sound keeps going off. When I am watching a video on youtube, or listening to a song, and it goes off, I have to refresh the page, because the audio cuts out. is there a way to fix this, as it's VERY annoying!
[Flash Player] "enable hardware acceleration" missing !
I cant see that option anymore when right-clicking a video -on both IE and chrome and going to setings !
Browsers & Mail
