No audio except front speakers (Dell, Realtek Audio)
dagi
Britain
Hi all,
I'd be grateful for any advice to my problem....
Last month I bought a new PC, a Dell XPS 8500 with an Intel Core i7-3770 processor. The PC has onboard audio (Realtek High Definition Audio).
I didn't buy new speakers as I have a perfectly usable set of Creative 6.1 speakers.
My problem is that although my computer plays Windows event sounds through all the speakers, applications such as iTunes only emit sound through the front pair.
I have googled the problem and as a result have configured the Realtek to use 7.1 audio but without the side pair.
Also, I have disabled the Realtek driver and have reloaded by asking Windows to select the best available.
But still the problem persists.
Any ideas?
Thanks in advance,
dagi
    Windows 8 Pro
First, for proper operation you must use the Dell supplied sound driver. Non-Dell will either not work or install or will not work properly, and that includes the basic function Windows installed HD Audio Codec.
6.1 is an oddball speaker configuration for current technology systems, its either 2.1, 5.1 or 7.1.
I used to do a lot of support on the Dell users forum (community) and recall that certain applications will only play audio through "stereo" speakers only. My experience on the Dell forum (I had over 37,000 posts and am still registered) also is the reason I note the Dell supplied sound driver.
You could also post on the Dell community Desktop hardware section and one of the user experts there may have more suggestions.
Desktop - Dell Community
