ASUS Sonicmaster Subwoofer not working (not detected ?)
    Hi, I just bought a brand new ASUS N series today, and it came with a sonicmaster subwoofer, which unfortunately doesn't work. Whatever I play it comes out of the regular computer speakers, and I've made sure all the time that the sub was plugged correctly and at the right place (subwoofer jack, just like it says in the manual).
    So what can I do here ?
    Thanks for the help
    West Sussex
    Win 7 & Win 8pro 64 bit
    I'm having the same trouble in Windows 8 but it works lovely under 7 (I'm dual booting) I think there is a bit of software missing for 8 which I may have just found - will update shortly.
    West Sussex
    I received an ASUS driver disk with my laptop - I ran this under win 8 and it immediately didn't want to use it telling me it was for 7 only (which is why I had not tried it earlier). I ran it again under compatibility settings - BE VERY CAREFUL - only select the Audio driver + Sonic Master + Sonic Blast and of course anything you are SURE you want or you will overwrite all your drivers (which in 8 would be a bad idea).
    It works!! and by golly do it sounds grrrrrreeeaaat!! Good luck!
ASUS Recovery not Working on Windows 8!
So they say i can access the Recovery Menu if ASUS to reset the computer to standard through the F9 Button at startup, but the only thing that comes up is the Turn Off, Advanced Options and Continue to Windows 8 option, as it normally should when pressing F8. I want the Recovery, it is also...
Drivers & Hardware
Speaker Settings Subwoofer Crossover Not Working
I run a 7.0 speaker system connected in multi-channel analogue mode to my Creative X-Fi Titanium. I set my speaker settings on Windows 8.1 disabling the subwoofer and checking the full-range speakers checkbox to allow the low frequencies to be handled by my satellite speakers. I've made no...
asus external subwoofer
hi guys! i just want to know if the asus sonic master external subwoofer is compatible with other laptop lie lenovo g580? because my friend gave me this subwoofer and connect it to my lenovo laptop.but the sound coming out is very low.is there anything i can do? please help guys..thanks in...
Asus touchpad stoped working...
My Aus K55a touchpad did nto work anymore. I rolled back the driver and it works. I have lost all the nice scrolling features and just have a basic mouse function. I uninstalled and reinstalled the driver with the same result everytime. It will work for about a minute and completly stop. ANy...
Drivers & Hardware
RemoteFx not working but videocard correctly detected
I have a windows server 2012 R2 with 2 Hyper-V guest operating system. One of them is Windows 7 Sp1 Pro and the other is Windows 8.1 Enterprise. I want to use remotefx to connect to these guest os remotely. I have successfully installed remotefx on windows 7 and it work without issue. I...
Network & Sharing
Asus x202e battery not detected
Hello, I have an Asus x202e with I3, Win8 64 Bits. The defect is that the battery does not detect. Here's what I did: I disconnected the battery, I pressed the power button 30 seconds and not fixed. I reset BIOS F2, F9 and F10 and again not repaired. I uninstalled the Microsoft ACPI method battery...
Drivers & Hardware
Semi-working? Asus Fn Keys
Hi, Recently did a clean install of windows 8 on my Asus K53SV and the function keys work fine except for the brightness keys. Actually, at first i loaded the windows 7 atk package and the brightness keys worked but the volume ones didn't then i got the latest atk package and now the brightness...
Drivers & Hardware
