Solved No Sound
inwell
Hello,
I installed Win8 Ent Edition on my PC on new Partition (100 GB) Installation was fine and everything worked as charm except the AUDIO . I could not hear anything from my PC. I checked the DeviceManager but there is no Problem shown (yellow exclamation mark) and everything looks properly installed and working..
Win 8 installed drivers automatically but they do not suggest the name provided by the manufactures (ADI AD1986A SoundMAX High Definition Audio)
And one more query.. why my Win 8 Device manager shows AUDIO/SOUND devices twice ? (screen attached)
    Win 8 Ent 64 Bit
    Athlon 64bit
    Asus A8R-MVP
    4GB Kingston (2x2)
    ASUS EN 6600
    Seagate 500GB 7200 RPM
Does your MB have a built in sound ? if so you need to disable it from the BIOS, otherwise it will show up in device manager in addition to your sound card.
Windows 8 installed the default sound driver, you need to go to ASUS website, download the sound driver for your sound card then install it.
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    High Definiton Audio Device
    Generic
    1366x768
    Samsung 850 Pro 256GB
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
Yes,My MB has a built in sound (no additional PCI/PCIe card installed).
The motherboard site (ASUS) do not have drivers updated at all :( .. any help ?
    Win 8 Ent 64 Bit
    Athlon 64bit
    Asus A8R-MVP
    4GB Kingston (2x2)
    ASUS EN 6600
Manufacturers will not yet have drivers for Windows 8 but you can download driver for Windows 7 instead, most driver will work with Windows 8
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
Toshiba has full support and even an upgrade utility for windows 8. ^^ the only company i think that has an entirely free utility tool to help upgrade.
    windows 8 Pro x64
one more thing I noticed in devicemanager was Win8 installed drivers for SPDIF output...(there is one out connector on back panel) but im not sure how can I connect my existing speakers/headphones (3.5mm stereo jack) to that output...
regards
    Win 8 Ent 64 Bit
    Athlon 64bit
    Asus A8R-MVP
    4GB Kingston (2x2)
    ASUS EN 6600
topgundcp ,hello
Thanks for your time.
I v managed to solve the issue by installing Soundmax Analog Drivers for Windows 7 64bit...this setting is working fine for some time now....will be using this till Asus/Soundmax releases drivers for Win8
regards
    Win 8 Ent 64 Bit
    Athlon 64bit
    Asus A8R-MVP
    4GB Kingston (2x2)
    ASUS EN 6600
Hello Inwell,
Could you give some more detail to your solution? Which site did you download the drivers from and the steps for the successful install of the drivers. I have a similar setup except for the graphics card and my OS is just the 64 bit standard addition. However I cannot get the sound to work. Thanks.
    windows 8 64 bit
    AMD Athlon x2 4800+
    ASUS A8R-MVP
    2 GB DDR 400 CL2
    ATI Radeon X1900
topgundcp ,hello
regards
glad to hear it's working
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
Hello Inwell,
Hi,
download the drivers from Analog_Device_SoundMAX_6.10.02.6585.exe for the Win 7 64bit edition and run the setup.exe as usual . This worked for me and hope it will work for you too.
best wishes
    Win 8 Ent 64 Bit
    Athlon 64bit
    Asus A8R-MVP
    4GB Kingston (2x2)
    ASUS EN 6600
It worked! Thanks Inwell. I've spent days on this trying several drivers from various sites and the SoundMAX setup would always complain about how it can't install for the hardware.
Now I've just got to come up with a good excuse for the missus when the PCI soundcard drops through the door in the next couple of days:eek:( ordered it last night in frustration ). Unless someone can tell me the sound quality will be appreciably better ( it an ASUS Sonar DG 5.1, speakers are Logitech X-230 2.1 setup ), it will have to go back.
    windows 8 64 bit
    AMD Athlon x2 4800+
    ASUS A8R-MVP
    2 GB DDR 400 CL2
    ATI Radeon X1900
