kylebnjmnross
To start, hello. I'm new to these forums, and I joined because I need Windows 8 support.
About a week ago, I was wondering how I went about enabling the Startup sound to play. I discovered that in order to have any Startup sound playing, the option needed to be checked in Control Panel > Sounds. Coincidentally, I found that the Windows Logon/Logoff options were missing, so I went into the registry and changed the necessary 1's to 0's, and now they appear as they should. However, when I select a sound for them, it doesn't play when I log on. It is important to note that I'm under the impression that the Logon sound and Startup sound are two different things. The Startup sound I found that I could not change without messing up Metro, so I left it as the default Windows Vista/7 sound that plays. But if I am correct, there should also be a sound played when you log in or log off.
So, in short, how do I get the login/logoff sounds to play?
- Windows 8 64-bit
- System Manufacturer/Model
- Hewlett-Packard/HP Envy m6 Notebook PC
- Memory
- 8192MB RAM
- Graphics Card(s)
- Intel(R) HD Graphics 4000
