Sound only works in one running application at a time
    Windows 8 Pro
    Hi All,
    I'm a newbie here, so sorry if I haven't done a proper search on the forum to a solution for my problem, I tried but couldn't find an exact match. I had to dump my Sound Blaster X-FI card because of the pops and crackles, which I didn't have in XP. I'll try to resolve that problem by downloading Windows 7 drivers.
    So meanwhile I reverted back to the onboard sound card. Crackles and popping gone, but I can only get sound from one application at a time. For example if I run my DAW studio software sound is fine, then I switch to U-Tube, and no sound comes out from U-Tube. So it looks like it can handle only one dedicated application at a time. I can't recall this problem with Windows 98 or XP. Any ideas on how to fix it?
    Thanks a lot.
    Youtube uses Flash player. If you don't have it, get it. If you have it, reinstall it.
    Also, check the Sound/Recording section. The DAW software may be setting up a recording option that will not allow other sounds to come through. If not, make sure the Stereo Mix/System Mixer is set as the default recording device. This is needed for streaming audio from the internet.
    I have a recording studio using Sonar X2 Producer.
    Windows 8 Pro
    Thanks for the advice Fireberd. I tried everything but no browswer sounds would work, although system sounds and FL10 worked fine. I ended up disabling the on-board sound card and re-installing the Soundblaster X-FI card. All seems to be working normally now. So far the snap, crackle and pop is gone too, even using the CPU intensive Razor soft synth. If it don't work, re-install it!
    Still mystified though why no web browser sounds worked despite re-installing them and re-installing Flash, etc.
Hi, I have been having sound problems with the speakers on an HP Ultrabook. There are times when the laptop speakers stop working. When this occurs, I go to Control Panel>Sound, select the speakers(only one set to select), select Configure and Test. After selecting Test, I receive the message...
No sound on start-up, Win8 needs time to output sound
switch for running an application as administrator?
Greetings Is there a switch for running an application as an administrator like: regedit /a or regedit /admin? thanks
Windows sound control application
Has anyone made a sound changing app where you can change startup/shutdown sounds ect? Can you via registry and other tricks get sound to happen on fast boot and resume? I wonder if I could get windows task scheduler to do it...mmmm
Unknown application running on my pc
Hi all, yesterday i was performing some routing maintenance on my pc, and i noticed there was an evernt log showing an error of an application that was stored in the path. (Please note i didnt mistype VLC). C:\Users\{myuser}\Appdata\roaming\LVC\lvc.exe It was always giving me an error code...
Software and Apps
Disabling Aero and such while running a full screen application.
I've been using Windows 8 for the past couple of days and I gotta say, I've been loving every second of it, I do have one question though, is there a way to disable Aero and all similar graphical effects (transparency/glass effects, etc) when running a full screen application? (to save VRAM). I...
Sony VAIO Webcams - This application WORKS FINE
Hi all Until now I've found it a real problem getting the built in Sony VAIO webcam to work --drivers are fine but apart from SKYPE I was unable to find any stand alone application which would make the webcam work. However I copied the AMCAP program from an old Philips FREEVENT computer -- and...
Drivers & Hardware
