Change sound settings directly in the registry
    I was wondering if it would be possible to either change the speaker settings (switch between stereo, 5.1 etc.) or, preferably, sound balance directly in the registry. Until now, I've only been able to find the key for the speaker settings:
    However, the changes only go into effect for a particular application when the application is restarted. When I do it 'the normal way', the changes go into effect immediately.
    I haven't been able to find any key for the sound balance settings.
    Hoping for some suggestions... Thanks in advance!
    Houston, TX
    Windows 8 Pro x64
    Why u need that? You want to write script/macro? Cause if so don't look in Registry...
    I've already written scripts in AutoIt, but I'd prefer to edit the registry directly. I don't know if that is possible...
Can't Change Update Settings "Some settings are managed.."
Ever since upgrading to Windows 8.1 I haven't been able to change my update settings. The drop-down is greyed out and can't be clicked on. Above the drop down it says "Some settings are managed by your system administrator" I've deleted my user account and created a new one, but the problem...
Windows Updates & Activation
Settings>change pc settings problem
Problem with sound settings
So i just changed my sound settings(i dont know how) And now it is so. I have headphones as a laptop normal speakers(usb headphones) and when i unplug them i dont hear anything. If i plug my speaker system to headphone jack the speakers doesnt work. so can someone help me getting my settings...
Registry remnants, IE settings, recovering user file
Windows 8.1 Just before upgrading from Windows 8 to 8.1, I deleted, I believe, all files for malware like delta, babylon and some other ones alike. Renmant remainin registry, I would be reassuring to safely delete them also. Then: 1) Adwcleaner deleted the files from current user So when I...
How to change who can shutdown the computer from Registry
Hi folks, I was woundering if somebody here knows how to specify which users can shutdown the computer from registry. Using the local group policy this setting would be: Computer Configuration -> Windows Settings -> Security Settings -> Local Settings -> User Rights -> Shutdown the Computer ...
User Accounts and Family Safety
Change my desktop icons to 32 bits view in registry?
Hi, i'd like to change my desktop icons to 32bits view without having to install the laptop drivers 100mb or more video drivers. I prefer letting windows8 manage the display, without installing garbage video tools.. & adding more garbage to my vm. could you offer me a way to modify it in...
Install stalled at Updating Registry Settings
I am attempting to install the Dev edition of Windows 8 for testing with multiple monitors. I have it installed on 2 test boxes and 2 laptops but on the higher powered system the install stops at Setup is updating registry settings. The only major difference on the box is that it does have dual...
Installation & Setup
