wierd windows 8 sound issue
    Hallo there.
    I upgraded to windows 8 some weeks ago, as i got it trough dreamspark.
    I got this huge problem, on both my stationary, and my laptop
    sound keeps dissapearing for 4-5 secs every 2-4 mins. And it's really annoying.
    I got 2 soundcards on my stationary, and ive tryed using both of em as primary devices.
    One of em is integrated on the mainboard, and the other one is an external steinberg c1.
    On the laptop the card is integrated.
    Anyone had this issue before?
    Does not happen when im using spotify tho, only in certain games, and alot in VLC
    Win8.1 64 bits Ent- Pro
    no issue here, try and update both drivers and see whatcha get
    Houston, TX
    Windows 8 Pro x64
    Install Realtek HD Audio for Laptop and AC'97 or HD (depending what is your sound card using) on desktop. Set it as default...
Wierd Movie File Issue
I installed Windows 8.1 a couple of days ago and I am having a crazy issue with my movie files. Any file that dosnt show a thumbnail wont play, if however I drag it to the desktop it will display a thumbnail and play. If I try playing one in VLC it has an error 'of bad file descriptor'. I have...
Wierd hard drive disconnect issue. Details inside
Hello every one.I am having a very wierd issue with my hard drive dissapearing. When I Run a specific Bukkit Minecraft server (I have MANY servers with the EXACT same configurations and plugins;none of these have this problem) which is on my E Drive (Which is not a partition of my c drive) my C...
Drivers & Hardware
Windows 8 sound issue when using headphones
Hi. I recently bought a new pc and for the first few days the sound was working fine. This morning, some sound is not working, and some is working fine. Some youtube audio appears to be working and other youtube audio does not work at all. It seems like sound on certain frequency or band is working...
Sound issue
Hello! I have an HP laptop running Windows 8. Yesterday Windows updates were pushed across that I'm quite sure did not upgrade me to 8.1. Since then, after leaving the Chrome browser, I seem to have lost sound...and iTunes opens but will not play anything. To regain sound, I have to run...
Hello, After deciding to give windows 8 another shot and installing windows 8.1 i still stumbled upon the same issue i had before. sound - YouTube In first part of the clip you can hear sound in windows 7 and in second how it sounds in windows 8. While windows 7 sounds perfect, windows 8 has this...
DTS-HD in Windows 8 app - no sound, is this a codec issue?
Hello! Having a bit of a problem and trying to see if there is an easy solution. I have a Surface Pro and I want to watch some video on it. I wasn't able to find a specific video app that would play MKVs, but I did find Files&Folders which has a built in player that actually does! Been...
Sound issue Windows 8
Hello, I have sound issues on Windows 8 new desktop, in apps and in IE10 it dont play sound. When i open the "old" desktop and open in there Internet, its working. I have updated the Realtek sound card, but this not resolve the issue, does somebody know how to solve this issue?
