Windows 8 Forums
Page 1 of 2 12 LastLast
    dingoden's Avatar
    Logan City (Sth of Brisbane), Qld, AUS
    Australia au queensland
    Via HD Audio Deck
    After installing Windows 8, I get a dialog box saying my Via HD Audio deck is not compatible. Where can I download the suitable driver for this OS? Thanks
    fireberd's Avatar
    Beach Observer
    Citrus Co, FL
    Win 8 Pro, Win 7 Home
    USA us florida
    The first place to start is the PC Vendor (or if this is a custom build, the motherboard vendor) for drivers. Win 7 drivers, in most cases, work OK in Win 8.
    If the PC or Motherboard Vendor, as applicable does not have a compatible driver, you can try the Via site.
    VIA Drivers Download - VIA Technologies, Inc.
    dingoden's Avatar
    Sorry firebird, I should have said. ASUS Rampage 111 gene mobo. I went onto the VIA The website and re: the cookies I went into Internet Options and turned the Privacy right down and still not able to see the downloads. ASUS is not much better for the audio chip update. It is the nag screen saying update. In devices, it says you have the latest driver.
    There is no problem with audio.
    Thanks for your help.
    fireberd's Avatar
    Beach Observer
    Citrus Co, FL
    USA us florida
    I just went on the VIA site and had no problem with accessing drivers. I don't have anything special setup in Internet Explorer. Just the default settings.
    dingoden's Avatar
    VIA HD Audio Deck
    Thanks for your trying. I still have a problem with the "need help" and opening the database. Here is a png file attached.Click image for larger version
    dingoden's Avatar
    Hi firebred, Went to other computer with Win 7 and IE 8. No problem. Now I just have to figure out what file to download and wonder why I have a problem on that page with this computer using win 8 and IE 10?
    dingoden's Avatar
    OK I have downloaded and installed the V10500d (124mb) file from VIA Audio. the computer rebooted and looks fine. No dialog box abut the Via audio. Thanks for your help.
    I wonder if you are using IE10?
    alphanumeric's Avatar
    Sydney, Nova Scotia, Canada
    Windows 8 Pro with Media Center
    Canada ca novia scotia
    I had the same problem in IE 10, had to enable "compatibility view" to get that site to work correctly.
    dingoden's Avatar
    Mouse cursor sticks
    Thanks for that. I tried another mouse and the same thing happened. So I will do as you did and enable compatibility. I think that IE 10 is still quite new and may(?) have a few bugs(LOL)..
    dingoden's Avatar
    firebred. Update. I can now access that VIA Audio Deck site. I got a tip from the internet and put IE 10 in compatibility mode, that fixed it.
Via HD Audio Deck
Solved IDT hd audio not working Drivers & Hardware
Solved No audio, Asus N53SN, Realtek HD Audio Sound & Audio
Via HD Audio Deck do not support win 8. Sound & Audio
Via HD Audio deck Drivers & Hardware
any fix for via hd deck crackling sound in windows 8 Sound & Audio
