the Sound skipps and crackles- Hp Pavilion G6
    Hello there.
    At first, sorry for my English. I'm polish
    Ok. Yesterday I installed (again) Windows 8 ad after month since release, I have problems with sound :/
    It crackles, skipps, freezes etc
    As for me it's.. like a horror movie. Because I'm using my new laptop to gaming :/ watching movies and listening to the music.
    On Windows 7 everything worked like a charm. I reinstalled all drivers, and everything was ok.
    On Windows 8 upgrade or even clean install... it doesn't work :/
    Maybe someone already solved this problem?
    Did you install the correct sound drivers? The HP sound driver is the preferred driver. This is first step in trying to resolve problem.
    Windows usually will install the HD Audio Codec driver and that is not the correct driver.
    i get sound working I hope so... 3hrs of music, games and vids and it's ok
    I downloaded latest driver from hp's support forum.
    But now I have another problem... with WMP desktop... When I'm using it.. Music is playing but I can't switch it off by pressing X, change song.. Program is freezed, but sound is playing.
    I have to kill process Oo
    With Metro Music App everything is good.
    EDIT: DriverMax & sound driver update solved my problem
    Thanks for the feedback and its fixed.
I have a HP Pavilion Windows 8.
I want to know before taking apart my machine will my new Blu-Ray DVD Player out of my other computer fit ? The slot on my HP looks to narrow. Can you guys answer the question or should I try and find a HP Forum and ask them ? You guys have been so awesome and nice trying to help me, I...
Drivers & Hardware
Sound distorts or crackles in 8.1
So, a few days ago I installed Windows 8.1 on my old Toshiba laptop after couple of years of running 7 with no problems. Today while listening to music I noticed that the sound was distorting or crackling at certain times, now a week ago the headphone jack of the computer stopped working but the...
I have a HP Pavilion with Windows 8
People can believe than I still have and use regular a Palm Pilot Zire 31 (PalmOne) and it worked with XP and even Vista. I don't have those systems anymore and was needing to no if someone knows a site or link that can help me getting it to sync. Like a patch or something to that effect. The...
Software and Apps
usb sound box crackles and distorts with windows8
HI I have just had to upgrade to windows 8 from XP I am using a USB Presonus audio box which is an interface for my music software program cubase6. It worked fine with XP but windows 8 is 64 bit and now all my music is going into distortion does anyone know of a setting within windows to cure this...
HP Pavilion dv6-6110us No sound without Headphones
HP Pavilion dv6-6110us Entertainment Notebook PC laptop running windows 8 upgraded alright. Left the computer on overnight now the sound will not play through the computer speakers unless something is plugged into the headphone or microphone jack. But will play through external speakers... but not...
HP Pavilion Audio Stutter Help!
This is driving me nuts! Bought this Pavilion p6-2317c desktop a couple months ago. It has Win 8 x64, 8gb ram, and integrated IDT audio. It worked great out of box for a while, then I started noticing a slight break or stutter in music, whether online or on my hard drive. I tried installing fresh...
New Hp pavilion g7 - dpc watchdog error
Hello! I have searched this error in your forum and online and I have no idea how to solve it. This laptop is new - one week old - and I already get an error- I have no idea why. I suddenly started to get blue screens yesterday and I have no idea why Ii used your SF diagnostic tool an...
BSOD Crashes and Debugging
