Problem changing audio source
    Windows 8 Pro
    Hi there,
    I've just updated my rig and currently running windows 8 pro
    I am facing a problem where I have two audio source and wanted to change the source in the middle of the PC use
    I have a headphone connected to my Asus Xonar Phoebus and a Bose companion speaker connected straight to the USB
    When I used windows 7 I was able to go trough on half way of my streaming watch and change the Audio source just by going to the
    control panel > sound > and change the default device
    But seems like I am unable to do so in windows 8, problem is as I stream from my speaker, and I intended to change to headphone after I do the changing (control panel > sound > and change the default device); no sound coming up on the changed device and I have to reopen my browser; afterwards the sound would appear
    The sound would still come up after the change trough simple sound test from the "Sound" option in control panel but not for the streaming
    Would it be my windows 8 problem?or my browser (chrome)?
    Does anyone have different method to switches audio source? I find my way is long and troublesome
    Updated: Try to switching while listening on Itunes, nothing is wrong, guess its chrome ?
    Windows 8 / Win 7 Dual Boot
    It looks like each app is pinned to an audio device. I'm able to switch from laptop speakers to headphones by going into Playback Options (right click on speaker icon on desktop) and changing the default playback device. Sometimes, though, it will recognize when I plug in the headphones and auto-switch.
problem changing windows 8.1 lock screen image
Hello everyone! I have a strange problem when it comes to switching the image on my lock screen. I have a legitimate copy of windows 8, and I have just upgraded to the new windows 8.1. when I go to pc settings to change the lock screen background, I can see the default windows 8.1...
Delay audio to sync with different video source.
So I'm trying to sync a video source with a different audio source because it is around 30/40 seconds different. How can I delay the audio? RadioDelay software does not work because I have no external components. Stereo mix leads to an infinite looping.
Nvidia HD audio and Microsoft hd audio Driver problem
Video/Audio Problem
Hello, Just recently I've encountered a problem in watching a video in my laptop. I have NVIDIA GeForce GT740M, in case if it is related. When I was watching a video regardless of the player; VLC, Windows Media Player, PowerDVD, the video was messed up and hangs in still picture while the...
Major Problem Changing Open Apps
Ok, if I have an app and switch to another app, when I want to switch back to the app that is minimized by going to the top left corner of the screen to maximize the app, it does maximize, but as soon as I move my mouse from the top left hand corner where I opened the minimized app, it immediately...
Changing location of source\boot.wim on install media?
Hello. I'm trying create an USB stick with Windows 7 and Windows 8 installation files. For that I need move files to different directories so I have the following directory tree: X:\bootmgr X:\boot\BCD X:\Windows7\sources\boot.wim X:\Windows8\sources\boot.wim
Installation & Setup
audio problem in win 8
i have acer laptop v5 431 ,, the audio is dolby advance but after some time the audio quality has gone down and it does not feel like dolby anymore .plz help me . i have reinstalled drivers and windows says that there is some problem and the anhancements need to be disabled .. after disabling...
