Unable to get sound to work
kalkanprince
Hi All,
Wonder if you can help me... my PC used to be fine with Windows 7 and the upgrade advisor said everything would work just fine so I have done a clean install of Windows 8.
Initially I couldn't get my graphics card to work as it was an ATI X1300 so I went out and purchased a new Saphire Radeon HD5450 however I still am unable to get the onboard audio to work (which I am guessing is the unknown device in device manager) Does anyone have any suggestions please.
My PC spec is as follows (sorry for the long post but its detailed!)
HPDESKTOP
"Computer Name:","HPDESKTOP"
"Computer Brand Name:","HP Pavilion 061 RJ173AA-ABU m7670.uk"
"Operating System:","Microsoft Windows 8 Professional (x64) Build 9200"
Central Processor(s)
"Number Of Processor Packages (Physical):","1"
"Number Of Processors Cores:","2"
"Number Of Logical Processors:","2"
Intel Core 2 Duo E6600
"Processor Name:","Intel Core 2 Duo E6600"
"Original Processor Frequency:","2400.0 MHz"
"Original Processor Frequency [MHz]:","2400"
"CPU ID:","000006F6"
"CPU Brand Name:","Intel(R) Core(TM)2 CPU          6600  @ 2.40GHz"
"CPU Vendor:","GenuineIntel"
"CPU Stepping:","B2"
"CPU Code Name:","Conroe-4M"
"CPU S-Spec:","SL9S8, SL9ZL"
"CPU Thermal Design Power (TDP):","65 W"
"CPU Max. Case Temperature (Tcase_max):","60.1 °C"
"CPU Type:","Production Unit"
"CPU Platform:","LGA775 (FC-LGA6)"
"Microcode Update Revision:","D0"
"Number of CPU Cores:","2"
"Number of Logical CPUs:","2"
"CPU LFM (Minimum):","1600.0 MHz = 6.00 x 266.7 MHz @ 1.1625 V"
"CPU HFM (Maximum):","2400.0 MHz = 9.00 x 266.7 MHz @ 1.3125 V [Locked]"
"CPU Current:","2400.1 MHz = 9.00 x 266.7 MHz @ 1.3125 V"
"CPU Bus Type:","FSB (QDR)"
"L1 Cache:","Instruction: 32 KBytes, Data: 32 KBytes"
"L2 Cache:","Integrated: 4 MBytes"
"Instruction TLB:","4 KB Pages, 4-way set associative, 128 entries"
"Data TLB:","4 MB Pages, 4-way set associative, 32 entries"
"FPU on Chip","Present"
"Enhanced Virtual-86 Mode","Present"
"I/O Breakpoints","Present"
"Page Size Extensions","Present"
"Time Stamp Counter","Present"
"Pentium-style Model Specific Registers","Present"
"Physical Address Extension","Present"
"Machine Check Exception","Present"
"CMPXCHG8B Instruction","Present"
"APIC On Chip / PGE (AMD)","Present"
"Fast System Call","Present"
"Memory Type Range Registers","Present"
"Page Global Feature","Present"
"Machine Check Architecture","Present"
"CMOV Instruction","Present"
"Page Attribute Table","Present"
"36-bit Page Size Extensions","Present"
"Processor Number","Not Present"
"CLFLUSH Instruction","Present"
"Debug Trace and EMON Store","Present"
"Internal ACPI Support","Present"
"MMX Technology","Present"
"Fast FP Save/Restore (IA MMX-2)","Present"
"Streaming SIMD Extensions","Present"
"Streaming SIMD Extensions 2","Present"
"Self-Snoop","Present"
"Multi-Threading Capable","Present"
"Automatic Clock Control","Present"
"IA-64 Processor","Not Present"
"Signal Break on FERR","Present"
"Streaming SIMD Extensions 3","Present"
"Carryless Multiplication (PCLMULQDQ)/GFMUL","Not Present"
"64-Bit Debug Store","Present"
"MONITOR/MWAIT Support","Present"
"CPL Qualified Debug Store","Present"
"Virtual Machine Extensions","Present"
"Safer Mode Extensions (Intel TXT)","Not Present"
"Thermal Monitor 2","Present"
"Supplemental Streaming SIMD Extensions 3","Present"
"Enhanced SpeedStep Technology","Present"
"L1 Context ID","Not Present"
"Segment Limit Checking","Not Present"
"Fused Multiply Add","Not Present"
"CMPXCHG16B Support","Present"
"Send Task Priority Messages Disabling","Present"
"Performance/Debug Capability MSR","Present"
"Processor Context ID","Not Present"
"Direct Cache Access","Not Present"
"Streaming SIMD Extensions 4.1","Not Present"
"Streaming SIMD Extensions 4.2","Not Present"
"Extended xAPIC","Not Present"
"MOVBE Instruction","Not Present"
"POPCNT Instruction","Not Present"
"TSC-deadline Timer","Not Present"
"AES Cryptography Support","Not Present"
"XSAVE/XRSTOR/XSETBV/XGETBV Instructions","Not Present"
"XGETBV/XSETBV OS Enabled","Not Present"
"AVX Support","Not Present"
"Float16 Instructions","Not Present"
"Random Number Read Instruction","Not Present"
"64-bit Extensions","Present"
"RDTSCP and TSC_AUX Support","Not Present"
"1 GB large page support","Not Present"
"No Execute","Present"
"SYSCALL/SYSRET Support","Present"
"Read/Write FS/GS Base Instructions","Not Present"
"TSC_THREAD_OFFSET","Not Present"
"Bit Manipulation Instructions Set 1","Not Present"
"Hardware Lock Elision","Not Present"
"AVX2 Instructions","Not Present"
"Supervisor Mode Execution Protection","Not Present"
"Bit Manipulation Instructions Set 2","Not Present"
"Enhanced Performance String Instruction","Not Present"
"INVPCID Instruction","Not Present"
"Restricted Transactional Memory","Not Present"
"Cache QoS Monitoring","Not Present"
"RDSEED Instruction","Not Present"
"Multi-precision Add Carry Instructions","Not Present"
"Thermal Monitor 1:","Supported, Enabled"
"Thermal Monitor 2:","Supported, Enabled"
"Enhanced Intel SpeedStep (GV3):","Supported, Enabled"
"Bi-directional PROCHOT#:","Enabled"
"Extended Auto-HALT State C1E:","Enabled"
"Extended Stop Grant State C2E:","N/A"
"Enhanced Halt State C3E:","N/A"
"Enhanced Halt State C4E:","N/A"
"Enhanced Halt State Hard C4E:","N/A"
"Hardware Prefetcher:","Supported, Enabled"
"DCU Prefetcher:","Supported, Enabled"
"IP Prefetcher:","Supported, Enabled"
"Adjacent Cache Line Prefetch:","Supported, Enabled"
"MLC Streamer Prefetcher","Not Supported"
"MLC Spatial Prefetcher","Not Supported"
"DCU Streamer Prefetcher","Not Supported"
"DCU IP Prefetcher","Not Supported"
"Intel Dynamic Acceleration (IDA) Technology:","Not Supported"
"Intel Dynamic FSB Switching:","Not Supported"
"Enhanced Multi Threaded Thermal Management:","N/A"
"Intel Turbo Boost Technology:","Not Supported"
"Programmabe Ratio Limits:","Not Supported"
"Programmabe TDC/TDP Limits:","Not Supported"
"Maximum Physical Address Size:","36-bit (64 GBytes)"
"Maximum Virtual Address Size:","48-bit (256 TBytes)"
"Range 0-80000000 (0MB-2048MB) Type:","Write Back (WB)"
"Range 80000000-C0000000 (2048MB-3072MB) Type:","Write Back (WB)"
"Range C0000000-E0000000 (3072MB-3584MB) Type:","Write Back (WB)"
"Range 100000000-120000000 (4096MB-4608MB) Type:","Write Back (WB)"
"Range DFF00000-E0000000 (3583MB-3584MB) Type:","Uncacheable (UC)"
"Motherboard Model:","ASUS Basswood"
"Motherboard Chipset:","Intel P965 (Broadwater-P) + ICH8DH"
"Motherboard Slots:","5xPCI, 1xPCI Express x1, 1xPCI Express x16"
"PCI Express Version Supported:","v1.0"
"USB Version Supported:","v2.0"
"Internal Graphics:","Not Supported"
"PCI Express Port:","Supported"
"Mobile Features:","Not Supported"
"Quick Resume Technology:","Supported"
"SATA AHCI:","Supported"
"SATA RAID0/1/10:","Supported"
"SATA RAID5:","Supported"
"6 PCI Express x1 Ports:","Supported"
"USB Per-Port Disable:","Supported"
"BIOS Manufacturer:","Phoenix - AwardBIOS v6.00PG"
"BIOS Date:","09/18/06"
"BIOS Version:"," 3.08"
"BIOS Message:","Copyright 2006 by Hewlett-Packard Company Rev. 3.08"
"EFI BIOS:","Not Capable"
"Super-IO/LPC Chip:","Fintek A8000B"
ACPI Devices
Intel(R) 82802 Firmware Hub Device
"Device Name:","Intel(R) 82802 Firmware Hub Device"
"Memory Location:","FFB80000 - FFBFFFFF"
Programmable interrupt controller
"Device Name:","Programmable interrupt controller"
"I/O Port:","0020 - 0021"
"IRQ:","65792"
"I/O Port:","00A0 - 00A1"
System timer
"Device Name:","System timer"
"I/O Port:","0040 - 0043"
"IRQ:","0"
Direct memory access controller
"Device Name:","Direct memory access controller"
"DMA:","4"
"I/O Port:","0000 - 000F"
"I/O Port:","0080 - 0090"
"I/O Port:","0094 - 009F"
"I/O Port:","00C0 - 00DF"
"DMA:","4"
System speaker
"Device Name:","System speaker"
"I/O Port:","0061"
"I/O Port:","0061"
PCI Express Root Complex
"Device Name:","PCI Express Root Complex"
"I/O Port:","0D00 - FFFF"
"Memory Location:","000C0000 - 000BFFFF"
"I/O Port:","0000 - 0CF7"
"Memory Location:","000A0000 - 000BFFFF"
"Memory Location:","000C0000 - 000DFFFF"
"Memory Location:","DFF00000 - FEBFFFFF"
System CMOS/real time clock
"Device Name:","System CMOS/real time clock"
"I/O Port:","0070 - 0073"
"IRQ:","8"
System board
"Device Name:","System board"
"Memory Location:","000D4A00 - 000D7FFF"
"Memory Location:","DFEF0000 - DFFEFFFF"
"Memory Location:","FDFFA000 - FDFFAFFF"
"Memory Location:","000F0000 - 000F7FFF"
"Memory Location:","000F8000 - 000FBFFF"
"Memory Location:","000FC000 - 000FFFFF"
"Memory Location:","DFEE0000 - DFEFFFFF"
"Memory Location:","00000000 - 0009FFFF"
"Memory Location:","00100000 - DFEDFFFF"
"Memory Location:","FEC00000 - FEC00FFF"
"Memory Location:","FEE00000 - FEE00FFF"
"Memory Location:","FFB00000 - FFB7FFFF"
"Memory Location:","FFF00000 - FFFFFFFF"
"Memory Location:","000E0000 - 000EFFFF"
Motherboard resources
"Device Name:","Motherboard resources"
"I/O Port:","0010 - 001F"
"I/O Port:","0065 - 006F"
"I/O Port:","00E0 - 00EF"
"IRQ:","1114369"
"I/O Port:","0022 - 003F"
"I/O Port:","0044 - 005F"
"I/O Port:","0062 - 0063"
"I/O Port:","0074 - 007F"
"I/O Port:","0091 - 0093"
"I/O Port:","00A2 - 00BF"
"I/O Port:","04D0 - 04D1"
"I/O Port:","0800 - 087F"
"I/O Port:","0294 - 0297"
"I/O Port:","0880 - 088F"
"I/O Port:","0400 - 04BF"
"Memory Location:","F0000000 - F3FFFFFF"
Numeric data processor
"Device Name:","Numeric data processor"
"I/O Port:","00F0 - 00FF"
"IRQ:","13"
SMBIOS DMI
BIOS
"BIOS Vendor:","Phoenix Technologies, LTD"
"BIOS Release Date:","09/18/2006"
"BIOS Start Segment:","E000"
"BIOS Size:","1024 KBytes"
"System BIOS Version:","3.8"
"ISA Support:","Present"
"MCA Support:","Not Present"
"EISA Support:","Not Present"
"PCI Support:","Present"
"PC Card (PCMCIA) Support:","Not Present"
"Plug-and-Play Support:","Present"
"APM Support:","Present"
"Flash BIOS:","Present"
"BIOS Shadow:","Present"
"VL-VESA Support:","Not Present"
"ESCD Support:","Not Present"
"Boot from CD:","Present"
"Selectable Boot:","Present"
"BIOS ROM Socketed:","Present"
"Boot from PC Card:","Not Present"
"EDD Support:","Present"
"NEC PC-98 Support:","Not Present"
"ACPI Support:","Present"
"USB Legacy Support:","Present"
"AGP Support:","Not Present"
"I2O Boot Support:","Not Present"
"LS-120 Boot Support:","Present"
"ATAPI ZIP Drive Boot Support:","Present"
"IEE1394 Boot Support:","Not Present"
"Smart Battery Support:","Not Present"
"BIOS Boot Specification Support:","Present"
"Function key-initiated Network Service Boot Support:","Present"
"Targeted Content Distribution Support:","Present"
"UEFI Specification Support:","Not Present"
System
"System Manufacturer:","HP Pavilion 061"
"Product Name:","RJ173AA-ABU m7670.uk"
"Product Version:","0nx0114RE101BASSW00"
"Product Serial Number:","CZX640C5HM GB680"
"SKU Number:","RJ173AA#ABU"
"Family:","103C_53316J"
Mainboard
"Mainboard Manufacturer:","ASUSTek Computer INC."
"Mainboard Name:","Basswood"
"Mainboard Version:","1.05"
"Mainboard Serial Number:","MS1C69S14600575"
System Enclosure
"Manufacturer:"," "
"Case Type:","Desktop"
"Version:","1111"
"Serial Number:"," "
"Asset Tag Number:"," "
Processor
"Processor Manufacturer:","Intel"
"Processor Version:","Intel(R) Core(TM)2 CPU          6600  @ 2.40GHz"
"External Clock:","266 MHz"
"Maximum Clock Supported:","3800 MHz"
"Current Clock:","2400 MHz"
"CPU Socket:","Populated"
"CPU Status:","Enabled"
"Processor Type:","Central Processor"
"Processor Upgrade:","ZIF"
"Socket Designation:","Socket 775"
Processor
Memory Devices
Memory Controller
"Error Detecting Method:","8-bit Parity"
"Error Correction:","None"
"Supported Interleave:","1-Way"
"Current Interleave:","1-Way"
"Max. Memory Module Size:","1024 MBytes"
"Supported Memory Speed:",""
"Supported Memory Type:",""
"Supported Memory Voltage:","5 V"
"Associated Memory Slots:","4"
A0
"Socket Designation:","A0"
"Memory Type:",""
"Memory Speed:","Unknown"
"Installed size:","1024 MBytes"
"Enabled size:","1024 MBytes"
A1
"Socket Designation:","A1"
"Memory Type:",""
A2
"Socket Designation:","A2"
"Memory Type:",""
A3
"Socket Designation:","A3"
"Memory Type:",""
L1 Cache
"Socket Designation:","L1 Cache"
"Cache State:","Enabled"
"Cache Type:","Internal, Data"
"Cache Scheme:","Write-Back"
"Supported SRAM Type:","Synchronous"
"Current SRAM Type:","Synchronous"
"Cache Speed:","Unknown"
"Error Correction Type:",""
"Maximum Cache Size:","32 KBytes"
"Installed Cache Size:","32 KBytes"
"Cache Associativity:","4-way Set-Associative"
L1 Cache
L2 Cache
"Socket Designation:","L2 Cache"
"Cache Type:","Internal, Unified"
"Maximum Cache Size:","4096 KBytes"
"Installed Cache Size:","4096 KBytes"
L2 Cache
L3 Cache
"Socket Designation:","L3 Cache"
"Cache State:","Disabled"
"Cache Type:","Internal"
"Cache Scheme:","Write-Through and Write-Back"
"Error Correction Type:","Unknown"
"Maximum Cache Size:","0 KBytes"
"Installed Cache Size:","0 KBytes"
"Cache Associativity:","Unknown"
L3 Cache
Port Connectors
Port Connector
"Port Type:","Unknown"
"Internal Reference:","PRIMARY IDE"
"Internal Connector Type:","On Board IDE"
"External Reference:","Unknown"
"External Connector Type:","None"
8251 FIFO Compatible
"Port Type:","8251 FIFO Compatible"
"Internal Reference:","FDD"
"Internal Connector Type:","On Board Floppy"
Keyboard Port
"Port Type:","Keyboard Port"
"Internal Reference:","PS/2 Keyboard"
"Internal Connector Type:","PS/2"
"External Reference:"," "
"External Connector Type:","PS/2"
Mouse Port
"Port Type:","Mouse Port"
"Internal Reference:","PS/2 Mouse"
USB
"Port Type:","USB"
"Internal Reference:","Unknown"
"Internal Connector Type:","None"
"External Reference:","USB1"
"External Connector Type:","Unknown"
USB
"Port Type:","USB"
"External Reference:","USB2"
USB
"Port Type:","USB"
"External Reference:","USB3"
USB
"Port Type:","USB"
"External Reference:","USB4"
USB
"Port Type:","USB"
"External Reference:","USB5"
USB
"Port Type:","USB"
"External Reference:","USB6"
USB
"Port Type:","USB"
"External Reference:","USB7"
USB
"Port Type:","USB"
"External Reference:","USB8"
USB
"Port Type:","USB"
"External Reference:","USB9"
USB
"Port Type:","USB"
"External Reference:","USB10"
Video Port
"Port Type:","Video Port"
"External Reference:","VIDEO"
"External Connector Type:","DB-15 pin female"
Audio Port
"Port Type:","Audio Port"
"Internal Reference:","Line In"
"External Reference:","Line In"
Audio Port
"Internal Reference:","Back Surround L/R"
"External Reference:","Back Surround L/R"
"External Connector Type:","Mini-jack (headphones)"
Audio Port
"Internal Reference:","Side Surround L/R"
"External Reference:","Side Surround L/R"
Audio Port
"Internal Reference:","Center/LFE"
"External Reference:","Center/LFE"
Network Port
"Port Type:","Network Port"
"External Reference:","ETHERNET"
"External Connector Type:","RJ-45"
System Slots
PCI1
"Slot Designation:","PCI1"
"Slot Type:","PCI"
"Slot Usage:","In use"
"Slot Data Bus Width:","32-bit"
"Slot Length:","Short"
PCI2
"Slot Designation:","PCI2"
"Slot Type:","PCI"
PCI3
"Slot Designation:","PCI3"
"Slot Type:","PCI"
"Slot Usage:","Empty"
PCI4
"Slot Designation:","PCI4"
"Slot Type:","PCI"
PCI5
"Slot Designation:","PCI5"
"Slot Type:","PCI"
PCIEX16
"Slot Designation:","PCIEX16"
"Slot Type:","PCI Express"
"Slot Data Bus Width:","16x / x16"
On Board Device
"Device Description:"," "
"Device Type:","Unknown"
"Device Status:","Enabled"
"Device Type:","Video Adapter"
"Device Status:","Disabled"
"Device Type:","Ethernet Adapter"
"Device Type:","Audio Device"
BIOS Language
Physical Memory Array
"Array Location:","System board"
"Array Use:","System memory"
"Error Detecting Method:","None"
"Memory Capacity:","4194304 KBytes"
"Memory Devices:","4"
Memory Device
"Total Width:","64 bits"
"Data Width:","64 bits"
"Device Size:","1024 MBytes"
"Device Form Factor:","DIMM"
"Device Locator:","A0"
"Bank Locator:","Bank0/1"
"Device Type:","DDR2 SDRAM"
"Device Type Detail:","Synchronous"
"Memory Speed:","667 MHz"
"Manufacturer:","None"
"Serial Number:","None"
"Part Number:","None"
"Asset Tag:","None"
Memory Device
"Device Locator:","A1"
"Bank Locator:","Bank2/3"
"Asset Tag:","None"
Memory Device
"Device Locator:","A2"
"Bank Locator:","Bank4/5"
"Asset Tag:","None"
Memory Device
"Device Locator:","A3"
"Bank Locator:","Bank6/7"
"Asset Tag:","None"
Memory Array Mapped Address
"Starting Address:","00000000"
"Ending Address:","003FFFFF"
"Partition Width:","1"
Memory Device Mapped Address
"Ending Address:","000FFFFF"
"Partition Row Position:","1"
"Interleave Position:","Non-interleaved"
"Interleave Data Depth:","0"
"Starting Address:","00100000"
"Ending Address:","001FFFFF"
"Starting Address:","00200000"
"Ending Address:","002FFFFF"
"Starting Address:","00300000"
System Boot Information
"Boot Status:","No error occured"
System Configuration Options
OEM Strings
"Total Memory Size:","4 GBytes"
"Total Memory Size [MB]:","4096"
"Current Memory Clock:","333.3 MHz (5 : 4 ratio)"
"Current Timing (tCAS-tRCD-tRP-tRAS):","5.0-5-5-15"
"Memory Runs At:","Dual-Channel"
"Command Rate:","2T"
"Read to Read Delay (tRD_RD) Same Rank:","4T"
"Read to Read Delay (tRD_RD) Different Rank:","6T"
"Write to Write Delay (tWR_WR) Same Rank:","4T"
"Write to Write Delay (tWR_WR) Different Rank:","6T"
"Read to Write Delay (tRD_WR) Different Rank:","8T"
"Write to Read Delay (tWR_RD) Same Rank (tWTR):","11T"
"Write to Read Delay (tWR_RD) Different Rank:","5T"
"Read to Precharge Delay (tRTP):","5T"
"Write to Precharge Delay (tWTP/tWR):","13T"
"RAS# to RAS# Delay (tRRD):","3T"
"Refresh Cycle Time (tRFC):","35T"
Row: 0 - 1024 MB PC2-5300 DDR2-SDRAM Micron Tech. 16HTF12864AY-667F1
"Module Number:","0"
"Module Size:","1024 MBytes"
"Memory Type:","DDR2-SDRAM"
"DIMM Type:","Regular Unbuffered (UDIMM) "
"Error Check/Correction:","None"
"Memory Speed:","333.3 MHz (PC2-5300)"
"Module Manufacturer:","Micron Tech."
"Module Model:","16HTF12864AY-667F1"
"Serial Number:","716388824"
"Manufacturing Date:","Year: 2008, Week: 53"
"Module Width:","64-bits"
"Module Voltage:","SSTL 1.8V"
"SPD Revision:","1.2"
"Number Of Ranks:","2"
"Row Address Bits:","14"
"Column Address Bits:","10"
"Number Of Banks:","4"
"Supported Burst Lengths:","4, 8"
"Refresh Rate:","Reduced 0.5x (7.8 us)"
"Supported CAS Latencies (tCAS):","5.0, 4.0, 3.0"
"Min. RAS-to-CAS Delay (tRCD):","15.00 ns"
"Min. Row Precharge Time (tRP):","15.00 ns"
"Min. RAS Pulse Width (tRAS):","45 ns"
"Supported Module Timing at 333.3 MHz:","5.0-5-5-15"
"Supported Module Timing at 266.7 MHz:","4.0-4-4-12"
"Supported Module Timing at 200.0 MHz:","3.0-3-3-9"
"Min. Row-Activate To Row-Activate Delay (tRRD):","7.50 ns"
"Write Recovery Time (tWR):","15.00 ns"
"Internal write to read command delay (tWTR):","7.50 ns"
"Internal read to precharge command delay (tRTP):","7.50 ns"
"Minimum Activate to Activate/Refresh Time (tRC):","60.00 ns"
"Minimum Refresh to Activate/Refresh Command Period (tRFC):","105.00 ns"
"Address and Command Setup Time Before Clock (tIS):","0.20 ns"
"Address and Command Setup Time After Clock (tIH):","0.27 ns"
"Data Input Setup Time Before Strobe (tDS):","0.10 ns"
"Data Input Setup Time After Strobe (tDH):","0.17 ns"
Row: 1 - 1024 MB PC2-5300 DDR2-SDRAM Micron Tech. 16HTF12864AY-667F1
"Module Number:","1"
"Serial Number:","766720472"
Row: 2 - 1024 MB PC2-5300 DDR2-SDRAM Micron Tech. 16HTF12864AY-667F1
"Module Number:","2"
"Serial Number:","800274904"
Row: 3 - 1024 MB PC2-5300 DDR2-SDRAM Micron Tech. 16HTF12864AY-667F1
"Module Number:","3"
"Serial Number:","783497688"
Bus
PCI Bus #0
Intel G965/P965 Memory Controller Hub [C1/C2]
"Device Name:","Intel G965/P965 Memory Controller Hub [C1/C2]"
"Original Device Name:","Intel G965/P965 Memory Controller Hub [C1/C2]"
"Device Class:","Host-to-PCI Bridge"
"Revision ID:","2"
"Bus Number:","0"
"Device Number:","0"
"Function Number:","0"
"PCI Latency Timer:","0"
"Hardware ID:","PCI\VEN_8086&DEV_29A0&SUBSYS_2A36103C&REV_02"
"Interrupt Line:","N/A"
"Interrupt Pin:","N/A"
"Bus Mastering:","Enabled"
"Running At 66 MHz:","Not Capable"
"Fast Back-to-Back Transactions:","Capable"
"Driver Manufacturer:","Intel"
"Driver Description:","Intel(R) P965/G965 Processor to I/O Controller - 29A0"
"Driver Provider:","Microsoft"
"Driver Version:","6.2.9200.16384"
"Driver Date:","21-Jun-2006"
"DeviceInstanceId","PCI\VEN_8086&DEV_29A0&SUBSYS_2A36103C&REV_02\3&2411E6FE&0&00"
Intel G965/P965 PCI Express Root Port [C1/C2]
"Device Name:","Intel G965/P965 PCI Express Root Port [C1/C2]"
"Original Device Name:","Intel G965/P965 PCI Express Root Port [C1/C2]"
"Device Class:","PCI-to-PCI Bridge"
"Revision ID:","2"
"Bus Number:","0"
"Device Number:","1"
"Hardware ID:","PCI\VEN_8086&DEV_29A1&SUBSYS_00000000&REV_02"
"Version:","1.0"
"Maximum Link Width:","16x"
"Current Link Width:","16x"
"Maximum Link Speed:","2.5 Gb/s"
"Current Link Speed:","2.5 Gb/s"
"Device/Port Type:","Root Port of PCI Express Root Complex"
"Slot Implemented:","Yes"
"Hot-Plug:","Not Capable"
"Hot-Plug Surprise:","Not Capable"
"Slot Power Limit:","75.000 W"
"Active State Power Management (ASPM) Support:","L0s"
"Active State Power Management (ASPM) Status:","Disabled"
"Interrupt Line:","IRQ16"
"Interrupt Pin:","INTA#"
"Fast Back-to-Back Transactions:","Not Capable"
"Driver Description:","Intel(R) P965/G965 PCI Express Root Port - 29A1"
"DeviceInstanceId","PCI\VEN_8086&DEV_29A1&SUBSYS_2A36103C&REV_02\3&2411E6FE&0&08"
PCI Express x16 Bus #1
Sapphire Radeon HD 5450
"Device Name:","Sapphire Radeon HD 5450"
"Original Device Name:","ATI/AMD Radeon HD 5450/5470/5490/5530/6230/6250/6290 (CEDAR PRO)"
"Device Class:","VGA Compatible Adapter"
"Revision ID:","0"
"Bus Number:","1"
"Hardware ID:","PCI\VEN_1002&DEV_68F9&SUBSYS_E164174B&REV_00"
"Version:","2.0"
"Device/Port Type:","Legacy PCI Express Endpoint"
"Slot Implemented:","No"
"Active State Power Management (ASPM) Support:","L0s and L1"
"Memory Base Address 0","E0000000"
"Memory Base Address 2","FDDC0000"
"I/O Base Address 4","DE00"
"Driver Manufacturer:","Advanced Micro Devices, Inc."
"Driver Description:","ATI Radeon HD 5450"
"Driver Provider:","Advanced Micro Devices, Inc."
"Driver Version:","9.2.0.0"
"Driver Date:","27-Sep-2012"
"DeviceInstanceId","PCI\VEN_1002&DEV_68F9&SUBSYS_E164174B&REV_00\4&2122C6EF&0&0008"
ATI/AMD Cedar/Park/Robson - High Definition Audio Controller
"Device Name:","ATI/AMD Cedar/Park/Robson - High Definition Audio Controller"
"Original Device Name:","ATI/AMD Cedar/Park/Robson - High Definition Audio Controller"
"Device Class:","Mixed mode device"
"Revision ID:","0"
"Bus Number:","1"
"Function Number:","1"
"Hardware ID:","PCI\VEN_1002&DEV_AA68&SUBSYS_AA68174B&REV_00"
"Version:","2.0"
"Active State Power Management (ASPM) Status:","L0s and L1 Entry"
"Interrupt Line:","IRQ17"
"Interrupt Pin:","INTB#"
"Memory Base Address 0","FDDFC000"
"Driver Manufacturer:","Microsoft"
"Driver Description:","High Definition Audio Controller"
"Driver Version:","6.2.9200.16420"
"Driver Date:","19-Sep-2012"
"DeviceInstanceId","PCI\VEN_1002&DEV_AA68&SUBSYS_AA68174B&REV_00\4&2122C6EF&0&0108"
Intel 82562V 10/100 Network Controller
"Device Name:","Intel 82562V 10/100 Network Controller"
"Original Device Name:","Intel 82562V 10/100 Network Controller"
"Device Class:","Ethernet Adapter"
"Revision ID:","2"
"Bus Number:","0"
"Device Number:","25"
"Hardware ID:","PCI\VEN_8086&DEV_104C&SUBSYS_2A36103C&REV_02"
"Memory Base Address 0","FDFC0000"
"Memory Base Address 1","FDFFF000"
"I/O Base Address 2","0"
"Driver Description:","Intel(R) 82562V 10/100 Network Connection"
"Driver Provider:","Microsoft Corporation"
"Driver Version:","9.13.41.1"
"Driver Date:","27-Sep-2011"
"DeviceInstanceId","PCI\VEN_8086&DEV_104C&SUBSYS_2A36103C&REV_02\3&2411E6FE&0&C8"
Intel 82801HB ICH8 - USB Universal Host Controller #4 [B0]
"Device Name:","Intel 82801HB ICH8 - USB Universal Host Controller #4 [B0]"
"Original Device Name:","Intel 82801HB ICH8 - USB Universal Host Controller #4 [B0]"
"Device Class:","Universal Serial Bus (USB)"
"Revision ID:","2"
"Bus Number:","0"
"Device Number:","26"
"Hardware ID:","PCI\VEN_8086&DEV_2834&SUBSYS_2A36103C&REV_02"
"Interrupt Line:","IRQ23"
"I/O Base Address 4","FE00"
"Driver Description:","Intel(R) ICH8 Family USB Universal Host Controller - 2834"
"DeviceInstanceId","PCI\VEN_8086&DEV_2834&SUBSYS_2A36103C&REV_02\3&2411E6FE&0&D0"
USB Root Hub
[Port1] : No Device Connected
[Port2] : No Device Connected
Intel 82801HB ICH8 - USB Universal Host Controller #5 [B0]
"Device Name:","Intel 82801HB ICH8 - USB Universal Host Controller #5 [B0]"
"Original Device Name:","Intel 82801HB ICH8 - USB Universal Host Controller #5 [B0]"
"Revision ID:","2"
"Bus Number:","0"
"Hardware ID:","PCI\VEN_8086&DEV_2835&SUBSYS_2A36103C&REV_02"
"Interrupt Line:","IRQ19"
"I/O Base Address 4","FD00"
"Driver Description:","Intel(R) ICH8 Family USB Universal Host Controller - 2835"
"DeviceInstanceId","PCI\VEN_8086&DEV_2835&SUBSYS_2A36103C&REV_02\3&2411E6FE&0&D1"
USB Root Hub
Intel 82801HB ICH8 - Enhanced USB2 Controller #2 [B0]
"Device Name:","Intel 82801HB ICH8 - Enhanced USB2 Controller #2 [B0]"
"Original Device Name:","Intel 82801HB ICH8 - Enhanced USB2 Controller #2 [B0]"
"Revision ID:","2"
"Bus Number:","0"
"Function Number:","7"
"Hardware ID:","PCI\VEN_8086&DEV_283A&SUBSYS_2A36103C&REV_02"
"Memory Base Address 0","FDFFE000"
"Driver Description:","Intel(R) ICH8 Family USB2 Enhanced Host Controller - 283A"
"DeviceInstanceId","PCI\VEN_8086&DEV_283A&SUBSYS_2A36103C&REV_02\3&2411E6FE&0&D7"
USB Root Hub
[Port1] : USB Mass Storage Device
"Device Manufacturer:","Generic"
"Product Name:","Mass Storage Device"
"Serial Number:","058F312D81B1"
"USB Version Supported:","2.00"
"USB Device Speed:","USB 2.0 High-speed"
"Driver Description:","USB Mass Storage Device"
"Hardware ID:","USB\VID_058F&PID_6362"
"Driver Manufacturer:","Compatible USB storage device"
"DeviceInstanceId","USB\VID_058F&PID_6362\058F312D81B1"
[Port3] : No Device Connected
[Port4] : No Device Connected
Intel 82801HB ICH8 - PCI Express Root Port 1 [B0]
"Device Name:","Intel 82801HB ICH8 - PCI Express Root Port 1 [B0]"
"Original Device Name:","Intel 82801HB ICH8 - PCI Express Root Port 1 [B0]"
"Revision ID:","2"
"Bus Number:","0"
"Device Number:","28"
"Hardware ID:","PCI\VEN_8086&DEV_283F&SUBSYS_00000000&REV_02"
"Version:","1.0"
"Maximum Link Width:","1x"
"Current Link Width:","Not negotiated"
"Hot-Plug:","Capable"
"Hot-Plug Surprise:","Capable"
"Slot Power Limit:","10.000 W"
"Driver Description:","Intel(R) ICH8 Family PCI Express Root Port 1 - 283F"
"DeviceInstanceId","PCI\VEN_8086&DEV_283F&SUBSYS_2A36103C&REV_02\3&2411E6FE&0&E0"
PCI Express x1 Bus #2
Intel 82801HB ICH8 - USB Universal Host Controller #1 [B0]
"Device Name:","Intel 82801HB ICH8 - USB Universal Host Controller #1 [B0]"
"Original Device Name:","Intel 82801HB ICH8 - USB Universal Host Controller #1 [B0]"
"Revision ID:","2"
"Bus Number:","0"
"Device Number:","29"
"Hardware ID:","PCI\VEN_8086&DEV_2830&SUBSYS_2A36103C&REV_02"
"I/O Base Address 4","FC00"
"Driver Description:","Intel(R) ICH8 Family USB Universal Host Controller - 2830"
"DeviceInstanceId","PCI\VEN_8086&DEV_2830&SUBSYS_2A36103C&REV_02\3&2411E6FE&0&E8"
USB Root Hub
Intel 82801HB ICH8 - USB Universal Host Controller #2 [B0]
"Device Name:","Intel 82801HB ICH8 - USB Universal Host Controller #2 [B0]"
"Original Device Name:","Intel 82801HB ICH8 - USB Universal Host Controller #2 [B0]"
"Revision ID:","2"
"Bus Number:","0"
"Hardware ID:","PCI\VEN_8086&DEV_2831&SUBSYS_2A36103C&REV_02"
"I/O Base Address 4","FB00"
"Driver Description:","Intel(R) ICH8 Family USB Universal Host Controller - 2831"
"DeviceInstanceId","PCI\VEN_8086&DEV_2831&SUBSYS_2A36103C&REV_02\3&2411E6FE&0&E9"
USB Root Hub
Intel 82801HB ICH8 - USB Universal Host Controller #3 [B0]
"Device Name:","Intel 82801HB ICH8 - USB Universal Host Controller #3 [B0]"
"Original Device Name:","Intel 82801HB ICH8 - USB Universal Host Controller #3 [B0]"
"Revision ID:","2"
"Bus Number:","0"
"Function Number:","2"
"Hardware ID:","PCI\VEN_8086&DEV_2832&SUBSYS_2A36103C&REV_02"
"Interrupt Line:","IRQ18"
"Interrupt Pin:","INTC#"
"I/O Base Address 4","FA00"
"Driver Description:","Intel(R) ICH8 Family USB Universal Host Controller - 2832"
"DeviceInstanceId","PCI\VEN_8086&DEV_2832&SUBSYS_2A36103C&REV_02\3&2411E6FE&0&EA"
USB Root Hub
[Port1] : USB Composite Device
"Device Manufacturer:","Logitech"
"Product Name:","USB Receiver"
"Serial Number:","N/A"
"USB Version Supported:","1.10"
"USB Device Speed:","USB 1.1 Low-speed"
"Driver Description:","USB Composite Device"
"Hardware ID:","USB\VID_03F0&PID_0B0C"
"Driver Manufacturer:","(Standard USB Host Controller)"
"DeviceInstanceId","USB\VID_03F0&PID_0B0C\5&9C1F678&0&1"
Intel 82801HB ICH8 - Enhanced USB2 Controller #1 [B0]
"Device Name:","Intel 82801HB ICH8 - Enhanced USB2 Controller #1 [B0]"
"Original Device Name:","Intel 82801HB ICH8 - Enhanced USB2 Controller #1 [B0]"
"Revision ID:","2"
"Bus Number:","0"
"Hardware ID:","PCI\VEN_8086&DEV_2836&SUBSYS_2A36103C&REV_02"
"Memory Base Address 0","FDFFD000"
"Driver Description:","Intel(R) ICH8 Family USB2 Enhanced Host Controller - 2836"
"DeviceInstanceId","PCI\VEN_8086&DEV_2836&SUBSYS_2A36103C&REV_02\3&2411E6FE&0&EF"
USB Root Hub
[Port1] : NETGEAR WNDA3200 Wireless 11N Dual-band USB Adapter
"Device Manufacturer:","Netgear"
"Product Name:","WNDA3200"
"Serial Number:","12345"
"Driver Description:","NETGEAR WNDA3200 Wireless 11N Dual-band USB Adapter"
"Hardware ID:","USB\VID_0846&PID_9018"
"Driver Manufacturer:","Netgear Inc."
"Driver Provider:","Atheros Communications Inc."
"Driver Version:","2.0.0.57"
"Driver Date:","11-Oct-2010"
"DeviceInstanceId","USB\VID_0846&PID_9018\12345"
[Port2] : USB Composite Device
"Device Manufacturer:","Canon"
"Product Name:","MP280 series"
"Serial Number:","2A6A39"
"Hardware ID:","USB\VID_04A9&PID_1746"
"DeviceInstanceId","USB\VID_04A9&PID_1746\2A6A39"
[Port5] : No Device Connected
[Port6] : USB Composite Device
"Device Manufacturer:","Microsoft"
"Product Name:","Microsoft® LifeCam VX-7000"
"Hardware ID:","USB\VID_045E&PID_0723"
"DeviceInstanceId","USB\VID_045E&PID_0723\5&24AB96B6&0&6"
Intel 82801HB ICH8 Direct Media Interface Bridge [B0]
"Device Name:","Intel 82801HB ICH8 Direct Media Interface Bridge [B0]"
"Original Device Name:","Intel 82801HB ICH8 Direct Media Interface Bridge [B0]"
"Revision ID:","F2"
"Bus Number:","0"
"Device Number:","30"
"Hardware ID:","PCI\VEN_8086&DEV_244E&SUBSYS_00000000&REV_F2"
"Driver Description:","Intel(R) 82801 PCI Bridge - 244E"
"DeviceInstanceId","PCI\VEN_8086&DEV_244E&SUBSYS_2A36103C&REV_F2\3&2411E6FE&0&F0"
"Hub ID [ICH4]:","0"
"HP Unsupported [ICH5]:","Enabled"
"Hub Interface Timeslice:","0"
"Hub Interface Width:","8 bits"
"Hub Interface Rate Valid:","No"
"Hub Interface Rate:",""
"Maximum Data Bursts Per Packet:",""
"Device 7 Hide:","Visible"
"Device 6 Hide:","Visible"
"Device 5 Hide:","Visible"
"Device 4 Hide:","Visible"
"Device 3 Hide:","Visible"
"Device 2 Hide:","Visible"
"Device 1 Hide:","Visible"
"Device 0 Hide:","Visible"
"Subtractive Decode Policy:","Disabled"
"Device 8 Hide:","Visible"
"Discard Delayed Transactions:","Disabled"
"Block Delayed Transactions:","Disabled"
"Maximum Delayed Transactions:","2 Active, 5 pending"
"Auto Flush After Disconnect:","Disabled"
"Never Prefetch:","Disabled"
"Memory Read Multiple Prefetch:","Enabled"
"Memory Read Line Prefetch:","Enabled"
"Memory Read Prefetch:","Enabled"
"Prefetch Flush [ICH5]:","Disabled"
"High Priority PCI:","Disabled"
"15-16MB Hole:","Disabled"
"Discard Timer Mode [ICH2]:","128 PCICLKs (4 us)"
"32-Clock Retry [ICH2]/12-Clock Retry [ICH3/4/5]:","Disabled"
"Async Reads:","0"
"PCI Prefetch:","0"
"Multi-Transaction Timer Count Value:","0 PCICLKs"
"SERR# On Target Abort Receive:","Disabled"
"SERR# On Delayed Transaction Timeout:","Disabled"
PCI Bus #3
ASUS Tiger Capture Device
"Device Name:","ASUS Tiger Capture Device"
"Original Device Name:","Philips/NXP SAA7133/SAA7135HL Multimedia Capture Device"
"Device Class:","Unknown Multimedia Adapter"
"Revision ID:","D1"
"Bus Number:","3"
"PCI Latency Timer:","32"
"Hardware ID:","PCI\VEN_1131&DEV_7133&SUBSYS_48711043&REV_D1"
"Memory Base Address 0","FDEFF000"
"Driver Manufacturer:","ASUSTeK Computer Inc."
"Driver Description:","ASUSTeK Tiger Capture Device"
"Driver Provider:","ASUSTeK Computer Inc."
"Driver Version:","6.0.1.3"
"Driver Date:","04-Apr-2007"
"DeviceInstanceId","PCI\VEN_1131&DEV_7133&SUBSYS_48711043&REV_D1\4&1535F642&0&00F0"
AT&T/Lucent/Agere IEEE1394 FireWire
"Device Name:","AT&T/Lucent/Agere IEEE1394 FireWire"
"Original Device Name:","AT&T/Lucent/Agere IEEE1394 FireWire"
"Device Class:","Firewire (IEEE 1394) Serial Bus"
"Revision ID:","70"
"Bus Number:","3"
"Hardware ID:","PCI\VEN_11C1&DEV_5811&SUBSYS_2A36103C&REV_70"
"Interrupt Line:","IRQ20"
"Memory Base Address 0","FDEFE000"
"Driver Manufacturer:","LSI"
"Driver Description:","LSI 1394 OHCI Compliant Host Controller"
"DeviceInstanceId","PCI\VEN_11C1&DEV_5811&SUBSYS_2A36103C&REV_70\4&1535F642&0&08F0"
HP 802.11b/g Wireless Network Adapter [LiteOn]
"Device Name:","HP 802.11b/g Wireless Network Adapter [LiteOn]"
"Original Device Name:","Atheros Communications AR5006X 802.11abg Wireless NIC"
"Revision ID:","1"
"Bus Number:","3"
"Device Number:","3"
"PCI Latency Timer:","128"
"Hardware ID:","PCI\VEN_168C&DEV_001B&SUBSYS_500111AD&REV_01"
"Memory Base Address 0","FDEE0000"
"Bus Mastering:","Disabled"
"Driver Manufacturer:","Qualcomm Atheros Communications Inc."
"Driver Description:","HP 802.11b/g Wireless Network Adapter"
"Driver Version:","3.0.0.130"
"Driver Date:","03-Jul-2012"
"DeviceInstanceId","PCI\VEN_168C&DEV_001B&SUBSYS_500111AD&REV_01\4&1535F642&0&18F0"
Intel 82801HH ICH8DH - LPC Bridge [B0]
"Device Name:","Intel 82801HH ICH8DH - LPC Bridge [B0]"
"Original Device Name:","Intel 82801HH ICH8DH - LPC Bridge [B0]"
"Device Class:","PCI-to-ISA Bridge"
"Revision ID:","2"
"Bus Number:","0"
"Device Number:","31"
"Hardware ID:","PCI\VEN_8086&DEV_2812&SUBSYS_2A36103C&REV_02"
"Driver Description:","Intel(R) ICH8DH LPC Interface Controller - 2812"
"DeviceInstanceId","PCI\VEN_8086&DEV_2812&SUBSYS_2A36103C&REV_02\3&2411E6FE&0&F8"
Intel 82801HB ICH8 - SATA RAID 0/1/5 Controller [B0]
"Device Name:","Intel 82801HB ICH8 - SATA RAID 0/1/5 Controller [B0]"
"Original Device Name:","Intel 82801HB ICH8 - SATA RAID 0/1/5 Controller [B0]"
"Device Class:","RAID controller"
"Revision ID:","2"
"Bus Number:","0"
"Hardware ID:","PCI\VEN_8086&DEV_2822&SUBSYS_2A36103C&REV_02"
"I/O Base Address 0","F900"
"I/O Base Address 1","F800"
"I/O Base Address 2","F700"
"I/O Base Address 3","F600"
"I/O Base Address 4","F500"
"Memory Base Address 5","FDFFC000"
"Running At 66 MHz:","Capable"
"Interface Speed Supported:","Gen2 3.0 Gbps"
"Number Of Ports:","6"
"External SATA Support:","Not Capable"
"Aggressive Link Power Management:","Not Capable"
"Staggered Spin-up:","Not Capable"
"Mechanical Presence Switch:","Not Capable"
"Command Queue Acceleration:","Capable"
"AHCI Status:","Enabled"
"AHCI Version:","1.10"
"Ports Implemented:","0, 1, 2, 3, 4, 5"
"Port Status:","Device Present, Phy communication established"
"Current Interface Speed:","Gen2 3.0 Gbps"
"External SATA Port:","Not Capable"
"Hot Plug:","Not Capable"
"Device Type:","SATA"
"Current Interface Speed:","Gen1 1.5 Gbps"
"Device Type:","ATAPI"
"Port Status:","No Device Present"
"Driver Description:","Intel(R) ICH8R/ICH9R/ICH10R/DO SATA RAID Controller"
"Driver Provider:","Intel"
"Driver Version:","8.6.2.1022"
"Driver Date:","07-Aug-2010"
"DeviceInstanceId","PCI\VEN_8086&DEV_2822&SUBSYS_2A36103C&REV_02\3&2411E6FE&0&FA"
Intel 82801HB ICH8 - SMBus Controller [B0]
"Device Name:","Intel 82801HB ICH8 - SMBus Controller [B0]"
"Original Device Name:","Intel 82801HB ICH8 - SMBus Controller [B0]"
"Device Class:","SMBus (System Management Bus)"
"Revision ID:","2"
"Bus Number:","0"
"Function Number:","3"
"Hardware ID:","PCI\VEN_8086&DEV_283E&SUBSYS_2A36103C&REV_02"
"Memory Base Address 0","FDFFB000"
"I/O Base Address 4","500"
"Driver Description:","Intel(R) ICH8 Family SMBus Controller - 283E"
"DeviceInstanceId","PCI\VEN_8086&DEV_283E&SUBSYS_2A36103C&REV_02\3&2411E6FE&0&FB"
Video Adapter
"Video Chipset:","ATI/AMD Radeon HD 5450/5470/5490/5530/6230/6250/6290 (CEDAR PRO)"
"Video Memory:","1024 MBytes of DDR3 SDRAM"
"Video Card:","Sapphire Radeon HD 5450"
"Video Bus:","PCIe v2.0 x16 (2.5 Gb/s) @ x16 (2.5 Gb/s)"
"Video RAMDAC:","Internal DAC(400MHz)"
"Video BIOS Version:","012.020.000.058.000000"
"Processor Clock:","157.0 MHz"
"Memory Clock:","200.0 MHz (Effective 399.9 MHz)"
"Memory Bus Width:","64-bit"
"Number Of Pixel Pipelines:","8"
"Number Of Unified Shaders:","80"
Monitor
HP Compaq LA2205 Wide LCD Monitor
Drives
Floppy Drives
(S)ATA/ATAPI Drives
ST3250824AS
"Drive Controller:","Serial ATA 3Gb/s"
"Drive Model:","Seagate ST3250824AS"
"Drive Revision:","3.AHH"
"Drive Serial Number:","9ND00KYT"
"Drive Capacity:","238,475 MBytes (250 GB)"
"Drive Capacity [MB]:","238475"
"Number of Cylinders:","16383"
"Number of Heads:","16"
"Sectors Per Track:","63"
"Bytes Per Sector:","Unknown"
"Bytes Per Track:","Unknown"
"Number Of ECC Bytes:","4"
"Number of Sectors:","16514064"
"Total 32-bit LBA Sectors:","268435455"
"Total 48-bit LBA Sectors:","488397168"
"Cache Buffer Size:","8192 KBytes"
"Controller Type:","Not Specified"
"Sectors Per Interrupt:","Total: 16, Active: 16"
"Max. PIO Transfer Mode:","4"
"Multiword DMA Mode:","Total: 2, Active: 2"
"Singleword DMA Mode:","Total: -, Active: -"
"Ultra-DMA Mode:","Total: 5 (ATA-100), Inactive"
"Max. Multiword DMA Transfer Rate:","16.7 MBytes/s"
"Max. PIO with IORDY Transfer Rate:","16.7 MBytes/s"
"Max. PIO w/o IORDY Transfer Rate:","16.7 MBytes/s"
"Transfer Width:","16-bit"
"Native Command Queuing:","Supported, Max. Depth: 32"
"TRIM Command:","Not Supported"
"Fixed Drive:","Present"
"Removable Drive:","Not Present"
"Magnetic Storage:","Present"
"LBA Mode:","Supported"
"DMA Mode:","Supported"
"IORDY:","Supported"
"IORDY Disableable:","Supported"
"Write Cache:","Present, Active"
"S.M.A.R.T. Feature:","Present, Active"
"Security Feature:","Not Present, Inactive"
"Removable Media Feature:","Not Present, Disabled"
"Power Management:","Present, Active"
"Advanced Power Management:","Not Present, Inactive"
"Packet Interface:","Not Present, Disabled"
"Look-Ahead Buffer:","Present, Active"
"Host Protected Area:","Not Present, Disabled"
"Power-Up In Standby:","Not Suppported, Inactive"
"Automatic Acoustic Management:","Not Suppported, Inactive"
"48-bit LBA:","Supported, Active"
"Raw Read Error Rate:","118/6, Worst: 99 (Data = 188745921)"
"Spin Up Time:","99/Always OK, Worst: 97"
"Start/Stop Count:","98/20, Worst: 98 (Data = 2151)"
"Reallocated Sector Count:","100/36, Worst: 100"
"Seek Error Rate:","87/30, Worst: 60 (Data = 494073512)"
"Power-On Hours/Cycle Count:","82/Always OK, Worst: 82 (Data = 15937)"
"Spin Retry Count:","100/97, Worst: 100"
"Power Cycle Count:","99/20, Worst: 99 (Data = 2003)"
"Reported Uncorrectable Errors:","100/Always OK, Worst: 100"
"High Fly Writes","100/Always OK, Worst: 100"
"Airflow Temperature / Exceed Count:","61/45, Worst: 46 (Data = 39.0 °C)"
"Temperature","39/Always OK, Worst: 54 (Data = 39.0 °C)"
"Hardware ECC Recovered:","69/Always OK, Worst: 47 (Data = 132820785)"
"Current Pending Sector Count:","100/Always OK, Worst: 100"
"Off-Line Uncorrectable Sector Count:","100/Always OK, Worst: 100"
"UltraDMA/SATA CRC Error Rate:","200/Always OK, Worst: 200"
"Write/Multi-Zone Error Rate:","100/Always OK, Worst: 253"
"Data Address Mark Errors","99/Always OK, Worst: 252 (Data = 1)"
ST3250824AS
"Drive Serial Number:","9ND03AMY"
"Raw Read Error Rate:","114/6, Worst: 94 (Data = 72407727)"
"Spin Up Time:","98/Always OK, Worst: 97"
"Start/Stop Count:","87/20, Worst: 87 (Data = 13844)"
"Seek Error Rate:","83/30, Worst: 60 (Data = 228471757)"
"Power-On Hours/Cycle Count:","82/Always OK, Worst: 82 (Data = 15841)"
"Power Cycle Count:","99/20, Worst: 99 (Data = 2002)"
"Airflow Temperature / Exceed Count:","65/45, Worst: 52 (Data = 35.0 °C)"
"Temperature","35/Always OK, Worst: 48 (Data = 35.0 °C)"
"Hardware ECC Recovered:","63/Always OK, Worst: 45 (Data = 60364106)"
"Data Address Mark Errors","100/Always OK, Worst: 253"
TSSTcorpCD/DVDW TS-H653L
"Drive Model:","TSSTcorpCD/DVDW TS-H653L"
"Drive Revision:","0314"
"Drive Serial Number:",""
"Serial Number:","TS-H653LFirmware    "
"Drive Type:","DVD+R DL"
"Drive Controller:","Serial ATA 1.5Gb/s"
"Ultra-DMA Mode:","Total: 2 (Ultra-DMA/33), Inactive"
"Removable Drive:","Present"
"Magnetic Storage:","Not Present"
"Drive can read:","CD-R, CD-RW, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD+R DL"
"Drive can write:","CD-RW, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD+R DL"
ATAPI   DVD D  DH16DYS
"Drive Model:","ATAPI   DVD D  DH16DYS"
"Drive Revision:","XH31"
"Drive Type:","DVD-ROM"
"Multiword DMA Mode:","Total: 2, Active: -"
"Drive can read:","CD-R, DVD-R, DVD-RW, DVD+R, DVD+RW, DVD+R DL"
Audio
"Audio Adapter:","ATI/AMD Cedar/Park/Robson - High Definition Audio Controller"
"Audio Controller Hardware ID:","PCI\VEN_1002&DEV_AA68&SUBSYS_AA68174B&REV_00"
"High Definition Audio Codec:","ATi RADEON HDMI"
"Audio Codec Hardware ID:","HDAUDIO\FUNC_01&VEN_1002&DEV_AA01&SUBSYS_1002AA01"
"Driver Description:","High Definition Audio Device"
"Driver Date:","25-Jul-2012"
"DeviceInstanceId","HDAUDIO\FUNC_01&VEN_1002&DEV_AA01&SUBSYS_00AA0100&REV_1002\5&15086343&0&0001"
Network
"Network Card:","Intel 82562V 10/100 Network Controller"
"Vendor Description:","Intel(R) 82562V 10/100 Network Connection"
"MAC Address:","00-18-F3-6E-CB-C5"
"Maximum Link Speed:","1000 Mbps"
"Transmit Buffer Size:","775168 Bytes"
"Receive Buffer Size:","387584 Bytes"
"Network Card:","HP 802.11b/g Wireless Network Adapter [LiteOn]"
"Vendor Description:","Unknown"
"MAC Address:","Unknown"
"Maximum Link Speed:","Unknown"
"Transmit Buffer Size:","Unknown"
"Receive Buffer Size:","Unknown"
"Network Card:","NETGEAR WNDA3200 Wireless 11N Dual-band USB Adapter"
"Vendor Description:","Microsoft"
"MAC Address:","C4-3D-C7-C7-3F-42"
"Maximum Link Speed:","104 Mbps"
"Transmit Buffer Size:","6201344 Bytes"
"Receive Buffer Size:","6201344 Bytes"
Ports
Serial Ports
Parallel Ports
USB
Root Hub
Root Hub
Root Hub
Root Hub
Root Hub
Root Hub
Root Hub
You may need to go to amd web and do an auto scan on you computer and let it detect to see if your drivers are upto date if not then it will install for you. If are up to date right see if your hd audio is i presume its realtek hd i had togo to my motherboard manufactures web and look for my board that supports win8. Give that a go.
Ive tried downloading realtek drivers but they never seem to install, it runs a setup, puts files in program files x86 but still no drivers / sound
Ok if you right click computer then click manage then hardware are there any yellow ? marks or red x. If some are right click and properties and update drivers. Also can you access you realtek audio application it will be in control panel if installed or type realtek hd audio in programs. Right click speaker and see if it is muted. Try this Download HP Driver Updates and ATI Radeon HD 5450 Display Driver 8.982.9.0 for Windows 8 x64 Download - ATI Radeon HD 5450 Display Drivers Download or Realtek Drivers Download - Realtek
I have similiar problems with my laptop (Hp Pavilion G6, IDT Audio HD). Sound crackles, skippes, freeezes :/ As I can see it's popular issue with W8 or Drivers...
Sorry to bump anyone any ideas please? Really disappointed with MS as the upgrade advisor told me everything would work just fine! What a waste of money Win 8 is proving to be
Press alt cntrl delet click bottom and have a look at processes that are working and also for start up. If you see realtek see if it is enabled if not do so. And look to see if you have two different ones running. if nothing is running about sound then drivers maynot be installed.
Also try uninstalling the realtek controls that worked for seven or eight and reinstal it or look for the one that will work on eight. If you have two audio controls that can stop sound from working. Are you able to locate you realtek controls, usually in control panel. If you cannot locate the realtek controls maybe not installed. Go to where you uninstal softwear anf see if realtek driver is there. Sometimes you will require the sound drivers from your computer manufacturer and not the ones from like softpedia ect.
