I have problem with sound on my laptop
    I have problem with sound on my laptop after I download windows 8 on my laptop. I could not hear any sound at all. my laptop model is dell inspiron 1420(old model) and it previously run windows xp. why is that happen? is it not compatible with my lappy or else? can you help me to solve this problem ? I have no idea at all to solve this thing. thanks a lot .
    Hi Mieza,
    I had the same problem with XP (No Sound) at all after Win 8 pro Upgrade..
    Thing is I looked that hard I forgot the link Page.
    This is the Microsoft (Hotfix) link, but like I said can't remember the site.
    Hotfix link..(
    20XP/latest/UAA HD Audio OOB release/5011/free/198658 intl i386 zip exe
    You Download Hotfix, It will upload to your C:/ drive.
    Goto settings..Device manager..Network controller, in their you
    will see (Update Driver) click (Update Driver) and if will install (Xear 3D) CMI Audio.
    You should. have all bells ringing.
    I also have no (Wifi) Win 8 knocked out my (Creatix 802 11g) Driver.
    Cant find a replacement yet.
    I Have the zip folder on my deasktop, if any moderator can tell me how
    to upload it, (198658_int zip).
    OK, i believe i have the solution. I have a 7 year old Dell Latitude D510 which i ungraded to Win8 from XP Pro this week.
    And, like you, the audio didn't work. Your Inspiron and my Latitude use the exact Sigmatel driver.
    This is what you do - it worked perfectly for me, so here's hopin' - download the one listed here to your desktop:
    Drivers and Downloads | Dell [United States]
    Click on it to unpack to c:\dell\drivers\Rxxx (sound driver) Now, go into Device Manager, and under Sound, go into properties and under 'driver' chose 'update driver' and chose to manually update. Chose path c:\dell\drivers\Rxxx\...\WMP and click OK. Restart and sound should work.
    Worked like a charm for me, so i hope it does for you as well. Actually, the driver for my Latitude may have even been older than the one for you Inspiron.
    Good luck and let us know how it goes,
    Hi AthanasianCreed,
    Thanks for your help, It worked like a charm.
    Excellent news - glad to hear!
My Laptop suddenly turns off sound
When I play game or listen to music, It suddenly turns off sound. If I hit the mute button and hit again, It will OK. Or, I change the volume, It works.But after time, It turns off.Is this hardware or software problem. I remember that everything is OK before I bring my laptop to Clean Center. What...
Laptop fan sound
Hello, I bought a laptop 2 weeks ago and the fan was really silent until now (I always thought it is not running), and today I started hearing it, it is not running at full speed like when playing a game or using a demanding software, however it is quite loud and the buzz is really annoying when...
No Sound in Videos - No changes Made to Laptop
hi, I have an Acer Aspire V5 laptop.It has a celeron cpu,and is a basic small laptop. I listen to video news online,and i have not installed or uninstalled any software prior to the problem of no sound in videos since it last played back video with sound. I have tried to play the same video...
HP laptop No sound problem
hey all i have a hp pavilion dv6-6150us ,,i was on youtube and suddenly the sound stopped working ,,no sound coming out from the laptop speakers ,, my on-board sound card is IDT ,,i downloaded the correct driver fro hp site ,,but it wont install ,, showing an error that the hardware detected is...
No sound from laptop all of a sudden
I tried to play songs in windows media player but it showed some error. Then i switched to VLC just to find out that there is some problem with the sound. When I clicked on the volume icon to see if the volume levels are ok, I found the computer icon, which appears there to be like as if there is a...
Major sound problem with new laptop and Windows 8
Erratically the sound (which is not always available) will accentuate to a high-pitched scream which necessitates closing the ears and turning down the volume control which is not maximal. With the speakers volume control at about 30%, tapping on the betzel or the screen is greatly ...
No Sound on my laptop (Except headphone)
Hi, I've just got my Windows 8 through Dreamspark Premium. I was using windows 7 and did a clean install of windows 8. After installing windows 8, there's no sound from my speaker. Sound only works with earphones. What should I do? My laptop: Asus N53J **UPDATE** I went to the asus...
