Annoying problem with sound crackling and skipping
  1. #31
    windows 8 pro
    Ok that was the bummer. It's all appeared that Windows 8 is not so much of a culprit actually. It's working absolutely fine as a 32bit installation on my comp. So it simply sppears that Windows 8 64bit demands the better hardware I mean not older than a 2 year comp probably and a bit newer drivers for Windows 8. I've been trying all the features for 2 days and sound etc. are working fine.
    La Fin...thanks to all.
  2. #32
    This is what I get in Windows 8 with my 4 year old desktop. I don't always get the pops and skipping. Wish I could figure this out.
  3. #33
    I haven't read through the whole thread so I don't know what you've tried, but the Ethernet controller is usually a big culprit.
    Go into device Manager, and expand Network Adapters. Find your Ethernet controller and rt. click it, then select disable.
  4. #34
    Linux Ubuntu and Windows 7 and 8.1
    You should try the following. The Power plan set to high perfomance, as this will reduce DPC latency. DPC latency may be the cause of why it occurs crackling sound.
Page 4 of 4 FirstFirst ... 234
Sound crackling/popping
I had crackling sound problem in my old computer, and now after building new one it still exist. All parts are new except RAM. When I watch video without pausing it there wont be any crackling, if i pause/play it fast there will be popping/crackling sound. Problem is pretty bad in...
annoying usb connect and disconnect sound
just bought a new computer with windows 8. ever since its a non stop sound of the usb being disconnected and connected. anyone have this problem? im about to throw my computer against the wall :mad:
Annoying sound pannel popup
Hi, anyone having this problem ? Every time I adjust my sound, the black sound pannel show up, but keeps showing up for like 1-2 minutes and it is pretty annoying. :( Is there a solution please ?
DPC issues, crackling sound, not sure if solved
Hello all, My sound had recently become stuttery, crackling, and sort of metallic sounding, maybe 'tinny' is the word. This is an issue both through HDMI and headphones. I've tried reinstalling and updating my drivers, I've cleaned a fairly nasty bit of dust from between the heatsink and fan,...
another sound crackling and skipping problem ! latencymon
so i have the sound problem here was using an-old 500GB HDD for OS and things got really out of control sound and even the mouse lagged so i poped out an-even older 80GB HDD :P and installed what i had on hand a windows 7 32bit and the PC ran like a chaaaaarm for like a week then i broke the piggy...
Sound Popping/Crackling
All right, so my sound is popping at loud frequencies. For example, if I click on my volume adjuster to hear the different sample levels, little pops and crackles can be heard. I was starting to notice some crackling when I got the Logitech g35. Thinking the g35 was faulty, I got a refund and a got...
any fix for via hd deck crackling sound in windows 8
is there any fix for via hd deck audio crackling sound in windows 8 consumer preview my specs processor i7 2600k motherboad asrock H61M-VS graphics nvidia gt520
