Bluetooth AVRCP 1.3 songtitles
    Win8 64bit
    Does anyone have good results with getting songtitles on a bluetooth stereo headset?
    I believe that AVRCP 1.3, the bluetooth system that is required for songtitles, is supported by Windows8. On my bluetooth headset (Sony MW600) systems that do not support it, like my old iPhone 3G, just show nothing. Systems that do support it, like my iPad and my old Win7 install with Widcomm bluetooth stack, nicely show song titles on playing.
    Windows 8 however shows only the text "Windows Sound" on my headset. This indicates it knows how to send information to the headset (hence AVRCP 1.3 seems to work), but somehow the actual songtitles don't quite make it that far. I tried the Metro music app, and the on the desktop Spotify. The latter supported song titles on Win7.
    Does anyone have insights or experiences to share?
    Sorry to say, but I have tried nearly every combination of the following Bluetooth adapters and Bluetooth stacks without satisfactory results:
    1.) Kensingtion 4.0 USB dongle (CSR)
    2.) Asus 4.0 USB dongle (Broadcom)
    3.) Cirago USB A10 (CSR)
    4.) UltechSmart (Broadcom)
    5.) Toshiba USB Nano (CSR)
    6.) Sabrent USB dongle
    7.) Marvel AVASTAR
    8.) Some other branded CSR
    1.) MS Windows 8 stack
    2.) Toshiba Bluetooth Stack for Windows (several versions, including 9.10.15)
    3.) CSR Harmony and a number of previous versions
    4.) BlueSoleil 10.0.470.0
    5.) Broadcom/Widdcom stack (multiple versions)
    6.) Asus Bluetooth software (Broadcom I believe)
    Not one of these stacks will give you song titles from the Windows 8 Music app, or from other Modern apps. CSR can provide song titles from Windows Media Player, but overall the stack is flakey with song titles. If you don't use a Bluetooth stereo that handles song titles, it is more reliable, and works with Modern Apps. But with song titles it ONLY works with Windows Media Player, and won't play audio from ANYTHING else. CSR will only play from Windows Media Center if Windows Media Player is also running, and even then WMC is basically acting as a remote for WMP.
    BlueSoleil is slightly better, in that it will also play audio from Windows Media Center as well as Media Player. It's support for BLE devices is literally the LEAST they could do. You have to delete and re-pair every single time you use your BLE mouse, for example.
    BlueSoleil will play audio from Modern apps like Music, but it will not display the song titles from anything other than WMP and WMC. No song titles from the Music app.
    Overall, I'm back to the Microsoft stack, because it is the most solid and reliable. It is a shame that it doesn't support song titles like an iPhone or iPad does, but apparently they've fixed that in Windows Phone 8, so hopefully they will fix that in the Windows Bluetooth stack as well.
Bluetooth Not Showing Any Bluetooth Devices
hi, my laptop had Windows 8.1 Pre installed to i installed Windows 8.1 Pro on it .. before upgrading, naturally all is working well, i backed up my Drivers using an Open Source Software i downloaded from SourceForge after upgrading, i installed all drivers, all is working well except for my...
Drivers & Hardware
Bluetooth Dongle Not Detecting Bluetooth Mobile
Hi all this is my first post/question so bear with me if it hurts the rules :eek: Ok now i bought this usb dongle today and installed it successfully on windows 8 for 4 hrs trying to make it connect my android phone to the pc using bluetooth but in vain. It worked one time but went of in an...
I used to pair my phone with my pc using blue ray with Win 7 but since I got Win 8 blue ray is gone. The advisor prior to upgrading said it was not compatible. Is there some way, now that I have Win 8 to retrieve or in any way get blue ray? Thank you Peter
Network & Sharing
Bluetooth not working
Hey guys, I just got this fancy new usb bluetooth v4 dongle! Nice. Now, when I plug it into my win8 desktop it installs the microsoft 2006 drivers and everything is okay, it works perfectly. However when I plug it into my win8 laptop (both are win8 pro) it installs the 2006 driver but says this:...
Drivers & Hardware
Acer TimeLineX Bluetooth Drivers(maybe all laptop bluetooth functions)
Hey guys, So i spent the entire day trying to figure out why my Bluetooth installed fine but after one restart it disappeared and it wouldn't come back. I finally figured it out that the FN+F2 (wireless/bluetooth switches) is what enables/disabled it HAHAHAHAHA. default (after startup): ...
Drivers & Hardware
Bluetooth Issues Sony Bluetooth Keyboard vgp-bkb1
I just set up win 8 on my computer and was going thru the process of connecting my bluetooth mouse and my bluetooth keyboard. My mouse connected automatically, no problems. When I went to connect my keyboard I got the usual prompt asking you to enter the code, but the code was not accepted no...
Drivers & Hardware
Hello again. I've got a problem with Bluetooth now. (Graphic Card Fixed) I tried Intel BT +HS, still not work, then I try the Azurewave BT, still not work. Can somebody help me please? (Model is ASUS X53E with Intel Pentium B950)
Drivers & Hardware
