As the title state I'm having trouble with getting my Turtle Beach sound card to work. I've tried running the driver installer under compatibility mode for both 7 and XP but both fail at finding the actual card.
I know this is a fairly older card and probably doesn't have much support behind it, so if anyone does not know a fix, I would appreciate any suggestions on a newer card that 8 will support. I mainly use the card for passing audio to my 5.1 reciever (it has both toslink and digital audio so any card that has one would be fine)
- Windows 8
