Solved External speaker fail
Kumabjorn
The internal speaker works fine, but when I plug in the external speaker, (speaker plug + USB) it seems to mute the whole system. Anyone else with the same issue?
    Win 8
Laptop? Make sure the speaker jack isn't set to Digital out instead of analog out.
    Windows 10 Education 64 Bit
    Asus
    Thermaltake TR 620
    Stock heatsink fan
    Logitech Wireless K350 Wave
    80 Mbps Down 30 Mbps Up
Yeah, they try to cram so much into laptops these days the jacks do double or even triple duty. My father had a very similar problem when he got his Acer Laptop. It supported Dolby Digital Surround Sound 5.1 out but only had the one audio out jack. To use normal speakers you had to switch the jack back to analog stereo out.
    Asus
    Thermaltake TR 620
    Stock heatsink fan
