Sound Problem
    Windows 8 PRO
    Sound Problem/Solved/ Guide
    If you have issues with sound follow guide
    Just update your windows 8
    Install realtek drivers for windows 8
    Problem Solved
Sound Problem
HP laptop No sound problem
hey all i have a hp pavilion dv6-6150us ,,i was on youtube and suddenly the sound stopped working ,,no sound coming out from the laptop speakers ,, my on-board sound card is IDT ,,i downloaded the correct driver fro hp site ,,but it wont install ,, showing an error that the hardware detected is...
Sound Problem
Hey Guys So i have an Asus laptop running on windows 8 pro. From the past 3 days, whenever I put my laptop on hibernation and switch it back on, the speaker doesnt seem to be working. I am not able to hear anything at all even if the volume is in max. The only go around is to restart the laptop...
Problem with sound when connecting the PC with my Sony TV
Hi everyone, When connecting my PC to my TV through HDMI cable sometimes the playback device does not recognise my TV. While the picture on my TV is great I don't get sound. Sometimes it works. I am not sure if this has to do with the cable ( its a good HDMI cable though) or with the graphics...
Graphic Cards
Problem with sound settings
So i just changed my sound settings(i dont know how) And now it is so. I have headphones as a laptop normal speakers(usb headphones) and when i unplug them i dont hear anything. If i plug my speaker system to headphone jack the speakers doesnt work. so can someone help me getting my settings...
Windows 8 surrogate-sound problem
Hi, I would ask you to help me with one very annoying problem. Approximately every 10min my win8 do a sound. The sound is little bit like when you connect something to usb port. I donīt know how decribe it... itīs sound like "hello something is new" :D Everything works well and...
Sound Problem
Hello i have a problem in the sound In w8 when i start the computer after a shut down, the sound doesn't work but if i restart the computer it works fine, it means every time i have to restart to have the sound working any idea?
I have problem with sound on my laptop
I have problem with sound on my laptop after I download windows 8 on my laptop. :( I could not hear any sound at all. my laptop model is dell inspiron 1420(old model) and it previously run windows xp. why is that happen? is it not compatible with my lappy or else? can you help me to solve this...
