Audio Advantage Micro USB Sound Card - Driver Not Compatible?
    Windows 8 Pro x64
    I have a Turtle Beach Audio Advantage Micro USB Sound Card. It has S/PDIF Optical Out which works great with my surround sound system. I tried installing the drivers on Windows 8 Pro x64 but it keeps saying "Please plug-in USB Audio Device device!". When I go to Device Manager and manually try to browse to the driver to update it I get the following message:
    Windows encountered a problem installing the driver software for your device
    Windows found driver software for your device but encountered an error while attempting to install it.
    Audio Advantage Micro Device
    The hash for the file is not present in the specified catalog file. The file is likely corrupt or the victim of tampering.
    If you know the manufacturer of your device, you can visit its website and check the support section for driver software.
    Does anyone know of a way to get the driver to install or know of a small USB sound card with S/PDIF Optical Out that is Windows 8 compatible?
    Windows 8 Pro x64
    I figured it out. I needed to do an advanced reboot and select disable signed driver verification.
    i have the same problem, but even after disabling driver signatures, when running the exe, the driver still doesn't recognize the usb sound card. It appears under my audio devices and i can use it with my headphones but i need it for surround sound.
    How did you get to manually select drivers, i only got an exe.
    Any help is much appreciated!
Install Desktop application on micro sdxc card
Hello. I have recently got a Linx 10 windows tablet (Intel atom based), but it only has 32gb of storage of which 24gb is available. I recently purchased a Micro sdxc class 10 card (benchmarked at 25mb/s read/write on the Linx10 with crystaldisk), i was hoping to install applications on it where...
Software and Apps
Forcing a Micro SD card to act as a permanent storage.
This advice was given in a previous thread: Create a shortcut on your desktop that points to the SD card. Give it an obvious name (like "SD" in my case) and then move it to the root of C: (as in C:\SD) or somewhere else convenient. Then, add that location (the shortcut) to the library. Voila! It...
The Creative Sound Blaster X-fi Xtreme Audio card works fine in Windows 8. The drivers for Windows 7 work without any problem and the Creative updater and control panel also work as they should in Windows 8. The drivers can be downloaded here for the X-Fi Xtreme Audio card - Creative Worldwide...
micro-sd card update?
Download Update for Windows 7 for x64-based Systems (KB976422) from Official Microsoft Download Center Do you guys know of a similar update for Windows 8.1? My micro-sd card worked just fine with Windows 7, but I've been having some issues lately. edit: sorry if this is in the wrong section....
Drivers & Hardware
Graphics Card not Compatible with W8 | Please Help
10412 Hello, Scenario I upgraded to Windows 8 couple of days back, everything was fine and all Windows apps were working fine. After about 48 hours, some apps would not open. I did a lot of searching but did not find any solution. I managed to call MS support, the guy gave me a file to...
Graphic Cards
Bootable Windows to go on internal micro sd card on smart phone !!
Hi there I haven't tried this yet but maybe later this wek when I get some spare time. If you have a phone with a separate micro sd card of large enough capacity could you install windows to go on it and then use this as a USB ext drive on a laptop to boot Windows to go. These cards are now...
Installation & Setup
Drivers & Hardware
