Problem with Java need help?
jimmyedwards
Hi to all , I have been having problems today trying to use my online banking because of Java, I think. I keep getting a application error when I try ,I went in security tab on internet options and looked for Microsoft VM but it is not there. I also don’t have Java in the list either but Java is on my pc.
I am enclosing a print screen capture of the error thanks to all in advance.
    dell inspiron 660s
    8 gb
    ie
    windows defender
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
Thanks for your reply, I downloaded 32 and 64 bit but I am still having the problem ,here is the error message
    dell inspiron 660s
    8 gb
    ie
    windows defender
What happens when you click "ignore" ?
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
This is the print screen when I click detail ,nothing happens when I click ignore.
    dell inspiron 660s
    8 gb
    ie
    windows defender
I have no idea. :(
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
Uninstall Java. Reboot. Run Ccleaner to clean files, then use its Registry cleaner. Install Java again.
    7601.18247.x86fre.win7sp1
    Self-built Intel based
    Intel DQ965MT
    Hyundai 2 GB DDR2 @ 333 MHz
    Thermaltake 450W
    Logitech M510
    Optimum Online, fast for US
    Pale Moon
Could I use Revo to uninstall and where is the best place to get Ccleaner.
    dell inspiron 660s
    8 gb
    ie
    windows defender
    Intel DQ965MT
    Thermaltake 450W
    Logitech M510
    Pale Moon
I tried all that said and the problem is still there ,here is my print screen of programs.
    dell inspiron 660s
    8 gb
    ie
    windows defender
I checked manage add-ons in internet options and I have java 32 bit but no java 64 bit.
Java 64 bit is in control panel programs and features as java 7 update 51 and java 7 update 51(64bit) but no java 32 bit. I have downloaded java 32 bit but I cant find it, anyone know how to download java 7 32 bit .
    dell inspiron 660s
    8 gb
    ie
    windows defender
I am still having this problem with java, I don't know and cant really tell if I have java 7 32 bit and 64 bit or not.
    dell inspiron 660s
    8 gb
    ie
    windows defender
The java 7 update 51 is the 32 bit java.{latest version. :) }
Try these settings in internet options:
What browser are you using ?
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
I am using internet explorer and sometimes chrome the same problem happens on chrome also.
    dell inspiron 660s
    8 gb
    ie
    windows defender
For IE 11>
For Chrome>
This is all I can think of for now.
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
You might want to have a look at this tool & give it a shot for repairing/removing Java completely, then starting over.
JavaRa is an effective way to deploy, update and remove the Java Runtime Environment (JRE). It can assist in repairing or removing Java when other methods fail
JavaRa - SingularLabs
    Win 7 32, Win 7 64 Pro, Win 8.1 Pro
    It's a Dell, Dude.
    Intel Caffinated Core Duo
    Father is bored too.
    4 GB
    NVidia something-or-another
    24" HD TV/Monitor/Alternative Dimensional Viewing Portal
    Fuzzy after a couple drinks
    2 or 3, depending on if it's a night they're arguing about having a "split personality crisis" because I partitioned the drive.
    Don't get on my case....man
    Scotch on the rocks on the weekends..
    Mad Catz Cyborg V7. Or maybe Cyborg Catz Are Mad At V7's??? I know it lights up...far out.
    currently being stalked by the cat...
    Never fast enough...
    Defeated by Mario...wait...OH...BRowser...
    Various
I see that I don't have java 64 bit enabled and I don't have the run antimalware software on activeX controls either
    dell inspiron 660s
    8 gb
    ie
    windows defender
You do have 64 bit enabled:
Where it says "32-bit a..." just extend the Architect column & you'll see 64 bit.
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
As far as I can see, you have the latest 32 & 64 bit java installed & enabled.
You should be having no problems with java. :)
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
