PC is going nuts and need help.
    it will slow down and force me to wait for everything. for me to get here, I had to click favorites then wait almost 2 minuted before the pc would let me proceed. then wait again before I could start looking to write this thread, which I hope is posted in the right place. and if I go to fast. I get a message at the bottom of the page. and I click on it and I get a message
    pop up even with something to click to tell me why it's not working. this is that pop up message in question.
    Austin TX metro area
    Does this happen also in Safe Mode [with or without Networking]?
    don't know what safe mode is. but it seems to be a good minute or so stop between any action including sending this message. meaning i'll get a message will come up saying the page is off line. (and it's not).
    it seems to have solved it salve but still don't know what happened. never happened before. oh well solved, thanks for the help.
IP Adressing driving me nuts
Hi All, Using win8.0 all up to date. I am trying to set up a DD-wrt router with a default IP Address of which is also the default Gateway. The previous router had as the Gateway and I had given the laptop I am using a static IP of When I try to access...
Network & Sharing
Installed W8 and transferred back my files, went nuts
installed W8 Downloaded games and apps i wanted took out hdd from my pc into the other pc that i had my backup on transferred 300GB of Pictures and programs (Photoshop, sony vegas etc.) moved the HDD back into my pc after successful file transfer i cant og into f.ex the Library now, when in...
Installation & Setup
Windows 8 laptop is driving me nuts.
My Windows 8 Lenovo laptop is basically brand new and is giving me all kinds of problems. First off, whenever I wake the PC up from sleep/hibernate, or unplug it from the power supply, the wifi adapter loses its internet connection and I have to reboot. Second, and this just started today, I...
C:\ Permissions Driving Me Nuts! - Windows 8
I recently updated to Windows 8 because it seemed a good idea. But I have noticed that Microsoft has gone nuts about security with this latest iteration of their OS. When I place programs on the C: Drive they all require administrator permissions to run even if you are an administrator and...
System Security
