Solved Uninstalling Grayed out Generic Volume Shadow copies
JeffL
Is there a fast way to delete the grayed out Generic Volume Shadow Copy drivers? I have a couple of thousand of them which I believe is the cause of Devices and Printers taking 2 to 3 minutes to load. I've started uninstalling the grayed out ones manually, but that is going to take forever.
    Dell Inspiron 660
    I5
    *GB
    FireFox
    Norton
    Windows 10 Pro 64 bit
    Dell Studio XPS 9100
    intel i7 920 @ 2.67 GHz
    Dell
    24 Gig
    ATI Radeon HD 5670
    Internal
    23" Flat Screen HDMI
    1366 x 768
    Samsung EVO 850 250 GB SSD
    2 Seagate internal 1TB
    WD external 3TB USB 3
    WD external 2TB USB 3
    550-W
    Mid
    Fans
    US USB
    USB
    3.84 Mbps Download .44 Mbps Upload
    IE11
    MS Defender
    Liteon DVD wrighter
    Liteon BD drive
    Monoprice Tablet
Be careful using Ghostbuster. There are some grayed out drivers that should not be removed. Also, any device not currently connected will appears as grayed out and you may not want to remove those.
What I did was right click on one of the Generic Volume Shadow Copy lines, clicked on Add Class (making it my only class). The good ones turned green, and the ghosts turned a darker sort of orange. Then I clicked on Remove Ghosts, and all the "ghosted" Generic Volume Shadow Copies went away.
    Dell Inspiron 660
    I5
    *GB
    FireFox
    Norton
I had hundreds of them as well. I deleted them through Windows disk cleanup. There is an option to delete all except the latest. Now they are gone from device manager.
    Windows 10 1511.14
I had tried Windows Disk Clean Up (I even checked Clean Up System Files), but it still left thousands of grayed out Generic Volume Shadow Copies. Ghostbuster did the trick for me. It now takes about a minute, instead of 3 minutes, to load Devices and Printers, but that's because I still have a ton of good Volume Shadow Copies. What I really wanted to get to is my printer queues, so I made I short cut to the printers and now I can get to them instantly.
    Dell Inspiron 660
    I5
    *GB
    FireFox
    Norton
