After running sfc /scannow the CBS.log reads :
can't repair bootmgfw.efi.mui, version 6.3.9600.17031 - file missing;
can't repair utc.app.json, version 6.3.9600.17747 - hash mismatch;
can't repair telemetry.ASM-WindowsDefault.json, version 6.3.9600.17747 - hash mismatch,
can't repair AMD64\CNBJ2530.DPB, version 6.3.9600.17415 - hash mismatch
I've tried Dism/Online/Cleanup-Image/RestoreHealth but no success.
The Telemetry files mentioned in KB3068708 are no longer available at Microsoft site.
I can't enter Command Prompt under "System Recovery" as the "Advanced Start Up" Screen shows only two buttons - Continue & Turn Off PC, the other two buttons (Use another Device for Start up & Troubleshooting) are missing. I also notice bootrec.exe is missing.
All these problems were detected after I tried to Install Windows 10 upgrade, both thru "Windows Update" & "using ISO image created with MediaCreationTool" - Installation failed at 24% with "Something Happened". The setuperr.log was blank.
Any solutions?
Any solutions?
- Windows 10 Home (64-bit)
- Computer type
- Laptop
- System Manufacturer/Model
- ASUS K55N -DS81
- CPU
- AMD A8-4500M
- Motherboard
- ASUSTeK Computer Inc
- Memory
- 4GB
- Browser
- Internet Explorer 11
- Antivirus
- Windows Defender
