USB Headset Makes Irritating Noise - USB Hub
    I own an Afterglow Prismatic wireless USB headset, and recently I've run into a problem. It had bee a long few months since I last used the headset, and when talking to friends in a voice-chat program, there seemed to always be a constant white-noise humming sound persisting. I took it as the microphone picking up the air around me, as it made a similar noise when not muted, but, I found that this was not the case after testing the mute button.
    I looked around online to see that many people with a similar problem claimed that their headphones made the noise due to improper power, whether it was from a bad USB port or because the rig was plugged into an un-grounded socket. This made me test to see if improper power was my problem, and I can only assume it is because when plugged directly into a port, there's no noise, whilst in the hub, there is. This normally wouldn't be a problem, as most laptops have quite a few ports, however, one of my three plain and simply don't work; zero power. The other two are fine, but, when plugging the USB headset into one of the ports, it blocks the other, make me unable to use a mouse or even the USB hub, which the mouse performs fine in.
    Too long, didn't read?
    How can I stop a humming sound from coming through my headset when plugged into a USB hub?
    Win 8.1.1 Pro x64
    Does your USB hub have its own power supply or it is just connected to the USB?
    I have had a similar problem and I have solved by buying USB hub with a power supply.
    When using a USB hub, you need a "powered" USB hub (one that has its own power supply). A non-powered is limited to whatever power is available when spread through all the devices attached to the hub and the internal PC hub's devices.
    Thanks for your posts, guys! They lead me to try and just plug the USB portion of the headset into one of the phone charger wall brick things, and plug the audio in into the audio port. I had assumed I needed the USB, because a few months prior, I had these same headphones and the audio cable got chewed up. Since the headphones still got sound, I assumed the audio in was just unnecessary. Marking as solved.
internal HDD makes weird noise
good evening.I just changed my internal HDD last month.the HDD did make a continuous high-pitched noise during Windows 8 installation.but when Windows 8 boots up, the noise dissapear.why this happens? (previous internal HDD didn't have this)lately, the laptop experiences freezes.sometimes it...
Drivers & Hardware
Really IRRITATING trend in browsers ALL including mobiles
Hi there PLEASE web site people can you ensure that web pages don't display like this --seems the latest trend in web page display whatever browser you are using and it's INCREDIBLY ANNOYING when you are trying to read the article. I know that advertising online is an incredibly difficult...
Browsers & Mail
Monitor LED blinks and makes a buzzing noise in hibernate.
I have an ASUS LED monitor and an MSI motherboard. When the computer goes into hibernate the blue LED indicator on the face of the monitor blinks. When it starts blinking there is a slight buzzing noise that is emitted. Since my computer is in my bedroom I was hoping to be able to change this so at...
Drivers & Hardware
Help With BSOD, (intelppm.sys). Too Much irritating
Hi, this is my first post here, and i am here with too much expectations. please. State; i'v just received Dell Inspiron Ultrabook 15z i7 with win 8 "40days ago". recently after heard about win8.1 free offer for win8 registered tagged user, i update to win8.1 from store. after that i first...
BSOD Crashes and Debugging
Irritating buzzing noise
Seem to be plagued with problems at the moment. Have just fixed one and now the Sandy Bridge is making a fairly loud buzzing noise a bit like a doorbell being pushed. It is fairly intermittent and the sound lasts for a few seconds or for a minute or so. It doesn't seem to be related to anything I...
Drivers & Hardware
Interesting startup problem, irritating
Hi. On Windows 8 since the upgrade from 7 and continuing after the recent Patch Tuesday. I have a situation after I log into Windows 8. After the Metro window arrives and a short while, I get a message "how would you like to open this file something like C:/programe.txt . So I choose...
Irritating Windows 8 Wifi - New problem - Urgent help need
14213 Windows 8 is a great operating system but recently over the past two days it has developed a dislike to my Wifi. I am connecting to a BT-Homehub within my house, all the drivers are the newest - I even changed the setting so Windows 8 couldn't turn the driver off when power was low as I...
