Help! laptop stuck at 28% charging
  1. #11
    Quote Originally Posted by clark2014 View Post
    ive been usin these for 2 years. im just hoping man that there's any other fix. if it's doesent have then i just go buy another one then
    Go to Device manager, right click Disk drives, Properties, then in Policy tab, untick "Enable Write caching on the device", it may work or may not work, I have done this on a SSD but not sure about HDD. If it doesn't work, tick the caching.
  2. #12
    windows 8 single language
    did not work. maybe its time to get a new battery thanks for all your help really appreciate it!
Page 2 of 2 FirstFirst 12
Samsung Laptop Not Charging
I think the laptop is fully functional but it can't charge. It ran out of battery now. I think the power supply is working because there was a green light :D. Is it caused by a problem in its motherboard?
Drivers & Hardware
Stuck configuring updates on new laptop
I just got my Lenovo Ideapad Y500 back from Lenovo today after it needed its hard drive and motherboard replaced. I turned it on, set it up, and spent a couple hours downloading and installing things, as well as transferring files and uninstalling all the freeware that came with it. I accidentally...
Windows Updates & Activation
Laptop Is Stuck?
I need help, it's been like this for a day or so and I really need my laptop. Idk how long this would take... 43473
HP laptop stuck on pink screen!!!
So I put my laptop into safe mode and then restarted. When it came on it was stuck on the pink screen. The only buttons displayed are the ease of access button in the lower left corner and the power button (with shutdown & restart options). It will not display the login screen or anything. I am...
Laptop charging but charge % staying the same?
Hello, I got a new laptop about 3 weeks ago or so and just today I noticed that it was charging but stuck at 95% I took the charger out let it drain down to 58% then put it back in again only to see that it's doing the exact same thing but now stuck on 58% I'm scared to drain the battery...
New laptop - 6 hours charging before initial startup?
Hello, I bought a new laptop with Windows 8, and I was told at the shop to charge it at least 6 hours before the first boot. Is it really necessary? And if yes, why? Thanks :D
Laptop stuck in restart loop?
I don't know why but it has randomly started doing this in this order- 1. I turn it on, it does the normal start up screen of "Toshiba" and the loading animation underneath. 2. After a long time of waiting it takes me to a black screen. It stays that way for about 5 minutes, sometimes it does not...
