Vicious Heat Problem with NV52L15u
  1. #11
    Windows 8.1 Pro x64 with Media Center
    The overheating issue could've been prevented if one would open up the bottom cover and rid the fan and heat sink with compressed air. Then again, a lot of laptops today have a bad layout from the bottom such that you need to disassemble all the way to the system board just to get to the fan and heat sink. That's why I only choose laptops whose fan and heat sink are easily accessible.
  2. #12
    yes theveterans..
    answer = asus llaptops from (rog gamers version..)
  3. #13
    Just another case of asking a boy to do man's job.
Page 2 of 2 FirstFirst 12
Is it possible to trick a heat sensor?
A few days ago, a strange bug occurred on my laptop; my fan started working at 100% output. Even when the temperature was 30c. Now, that is not the problem, rather it was something I wished my computer could do. After restarting my computer, the problem was fixed (I always put my laptop to...
Drivers & Hardware
Correlation between RAM speed and CPU heat?
I noticed that when i manually set my memory to 2133 mhz (as instructed by gskill, since my memory is 2133 but if i don't change it there it will be 1600), my cpu temps go like 5-8 șC higher. Is this normal? Is there a correlation between ram performance and cpu heat?
Drivers & Hardware
Inspiron N5010 Win 8.1 Pro I was downloading some Linux distros and now the laptop seems running hotter. I don't think it is related but I wanted to supply all I could think of. I read it was suggested to run w/o the battery which we have on order as this one is n/g. I also blew it all...
Drivers & Hardware
Fin out my PC heat via DOS
HI guys...i'm looking for a command to find out my PC heat via DOS . Can someone help me ? thank you .
bought new laptop after few issues with heat
hi i need to know where windows live mail in windows 8 stores its mail so i can access the old hard drive and get the mail from it if anyone can help id greatly appreciate it thanks forum
Browsers & Mail
Mobile space to heat up, Windows 8 may benefit from BYOD
Find out more.. Mobile space to heat up, Windows 8 may benefit from BYOD | ZDNet
Windows 8 News
Release Preview - Nothing but problem after problem after problem.
I had no problems with Customer Preview, everything worked, but, I must say that this Release Preview is another story all together. My PC hardware configuration is unchanged since installing Windows 7 when it came on to the market. 1. Doing a clean install did not install a clean...
