SidWiz1234
- Location
- India
Howdy! , after fixing the BSOD error my computer doesn't seem to show an error... although its performance has decreased a lot and plus i am facing problems in connecting to internet through USB.
The problems are:
1. slow performance ( its been acting much slower every since i fixed BSOD problem )
2. while connecting to internet using a USB dongle ( MTS ) i have to plug and unplug multiple times until my computer can finally and successfully connect to the internet otherwise it wont connection and show error that device has not been found
3. After number of tries i cannot see my Batter option. When i go to the properties this is what i see
I also tried using device manager to uninstall and re-install and also upgrade the driver but nothing worked and this is what i see
Also sometimes my computer hangs in between, specially when i do multi-tasking
I have attached the files as per needed. Please help me with this error
Thank you in advance View attachment SID-10-Dec-14_163608_35.zip
The problems are:
- Windows
