Power Plan Affecting WiFI?
    I was on a balanced power plan on my laptop while streaming on Netflix from my xbox. I couldn't get on any site on the laptop but I was able to use my iphone.
    On a hunch I switched to high performance and it works. Not sure if there is a relationship between power and the wifi on my laptop.
    Windows 3.1 > Windows 10
    go into advanced setting of your power plan - it may allow your wifi to turn off to save power
Power Plan changes each time on turn computer on
I have recently bought a new Asus machine running Windows 8.1. I have set my own custom plan for power settings in the control panel and have that selected. However when I turn the computer off then later turn it back on, the power plan has changed. It seems to do this every time. But it's...
how to remove entry's in win 8.1 power plan
Hi so is there any way to remove old not needed advanced entries in the windows 8.1 power plan settings. here is a picture of what i'm talking about. highlighted in red is what i don't need anymore any way to remove it?. 51352
Performance & Maintenance
Power Plan options not affecting performance
Hello there! For the longest while I've had issues with my Windows 8.1 ignoring my selection of power options. By this I mean by CPU will stay clocked at 1.4GHz when it should be hitting around 2.3GHz when I set to high performance from power saving mode. In the past it's cleared up by itself or...
Windows shuts down when closing laptop despite power plan
Hello, First of all, I'm Dutch and so is my Windows, so if some terms aren't quite as they should in English, I apologize and hope you still understand. :) I recently reinstalled Windows 8 completely because I bought an SSD for in my laptop. I exported my power plans I used before the reset...
Switching Power Plan Shortcut
I have a Dell XPS 13 and the F3 button has a battery sign on it. Pressing it brings up some battery meter property which does not really help as a day-to-day shortcut. Is there any way I can change that to toggling between two of my Power Plans ("Power Saving, High Performance") each time I press?
What Power Plan do you use?
As title suggests, what power plan do you normally use on Windows 8? Do you switch between power plans depending on the situation at hand? I run Balanced most of the time, since my AMD CPU has Cool'N'Quiet technology, then switch over to High Performance when gaming.
Power Plan Settings - Change in Windows 8
How to Change Power Plan Settings in Windows 8 and 8.1 A power plan is a collection of hardware and system settings that manages how your computer uses power. Power plans can help you save energy, maximize system performance, or achieve a balance between the two. This will show you how to...
