Trying to assess if I have a Win 8 problem or not
persius
About two weeks ago I began to notice strange behavior on my PC which made me think it may be a virus. Some examples:
1. When I'm online a message window frequently appears stating "internet explorer has stopped working"
2. Some websites do not display adverts on the page. I've attached a screenshot from youtube to illustrate what I'm referring to.
3. Some webpages will not load. I keep seeing "webpage under maintenance at this time". This is typical for websites at certain times but to see it every time I try to access is suspicious.
4. I use Hotmail and typically the first time I start it up in the day I notice that the first email I open causes the entire page to go blank as if it erases everything on it, it then reopens with all of my emails listed and finally the email I began to read will reopen. This only happens after I boot my system and open the first email. This will not happen on any other computer.
5. I seem to be having issues installing certain programs. They won't install citing various reasons such as outdated files, incompatible etc. These were all working flawlessly prior to reformatting my system.
6. On some websites there are forums which a allow viewer input. I'm unable to post messages even though I'm logged in. When I type a message I see the timer cycling but it never posts my messages, it's as if it's stuck in a loop or frozen.
Having felt that a system reformat was in order I did just that not more than a week ago. Everything was reinstalled and updated. Once all the Windows 8 files were installed I began to notice the exact same problems surfacing immediately. I have no idea where to start looking and what is causing this. If somebody can perhaps shed some light on the issue I would very much appreciate any thoughts that you may be able to share on how to fix this.
I'm currently using Win 8 with IE 10. 16 GB RAM, 64 bit OS.
The computer itself is an HP and a year old.
Thank you.
    HP
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
Hi
Before I can download IE 11 I need to upgrade to Win 8.1 and I first need to understand what's causing this problem. I would hate to upgrade only to continue running into the same issues.
    HP
8.1 and update 1 have resolved a lot of issues, they were not all cosmetic ones.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
I'm going to have to do something so I may as well upgrade to 8.1
Thanks for replying.
    HP
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
