Want CPU speed to always stay at maximum frequency?
realflow100
What software (besides high performance mode in windows control panel) can lock the CPU at it's highest frequency?
My CPU is Intel Celeron Quad Core 2.00Ghz
but it has a "burst" frequency up to 2.41Ghz (similar to turbo boost) and I would like it to stay at it's highest frequency since I have no worries about overheating
(never goes above 42* C at full load)
The problem is the speed constantly changes between 2.00Ghz 2.03Ghz 2.07Ghz (and so on ect... in between 2.00Ghz and 2.41Ghz) And my browser speed constantly goes up and down webpages stalling and going fast causing stuttering so I wonder what software can remedy this little problem?
Or if there is some kind of overclocking software that would do something similar to locking the frequency?
Tried all kinds of FSB-related tools but nada so far.
    Windows 7 x64 Ultimate Clean install
    Acer Aspire XC-603G
    Intel Celeron Quad Core 2.00Ghz Burst Frq 2.41Ghz
    Unknown at the moment
    4GB DDR3 1333Mhz
    Intel HD Graphics
    Realtek High Definition Audio Device
    HP Display
    1280 by 1024 at 60Hertz
    500GB HDD
    Stock/unknown
    Stock/unknown
    Stock
    Logitech Wireless
    Acer USB Mouse
    2.5MB/s down 252kb/s up
    Internet Explorer/Chrome
    Unknown//NA
you need to disable Intel speed step and C1E in the BIOS.
    Home Brewed
    I7 4970K OC'ed @4.7 GHz
    MSI-Z97
    NVIDIA GeForce GTS 450
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    Logitech Performance Mouse MX
    35/12mbps
:ditto:
    Windows 10.0.10122
    My Build - Vorttex Ultimate
    Core i7 @ 4500 MHz
    ASUS Z87-Plus
    32GB DDR3 @ 1822 MHz (OC)
    7.1 HDA
    LCD LG 22" + CRT LG 17"
    1760 x 1320 / 1280 x 960
    1 x 240 GB SSD (System)
    3 x 500 GB HDD (Data/Media)
    1 x 2000 GB e-HDD (Backup)
    ThermalTake 1000W PSU
    Corsair Carbide R300
    Corsair H60 (Push-Pull)
    Microsoft Wireless Keyboard
    Microsoft Wireless Mouse
    60 Mbps (Down) 5 Mbps (Up)
    IE, FF, Chrome
    AVG Internet Security 2015
    Some wired stuff
Unpark your Core's as well and change your Power-Profile to "High Performance".
You can unpark them via that tool here (my upload): Click
Should be packed with WinRAR-5.
Also assign manual the multiplyer for your cores and BCLK Frequency in your BIOS.
    Windows-10-Pro-Build-11099.rs1-x64
    Custom-Build
    Intel Core i7 3770k @4800MHz
    Asus P8Z77-V
    G.Skill 16G(4*4G) DDR3-2400 Quad Channel [TDX] F3-2400C10Q-16GTX
    2x Gigabyte GTX980-Ti-OC-STRIX-6GB in 2-Way-SLI (1408MHz | Boost: 1544MHz | Memory-Clock: 8000MHz)
    OnBoard Realtek® ALC892 8-Channel High Definition Audio
    Asus VE278Q 27" Wide Led Black Full HD 2ms | Dell S2409W 24" 5ms
    - Intel 520S 240GB/SATA3/R 550MBs,W 520MBs/25nm/3.5"Kit/5yr
    - Samsung 840 EVO SATA3 500GB
    - Seagate Barracuda SATA3 1TB 7200RPM 64mb Cache
    - Seagate Constellation SATA3 3TB 7200RPM 64mb Cache
    Corsair AX1200i
    Thermaltake Level-10 GT LCS
    EK H3O HFX 240mm Liquid Cooling Kit + 2x EK-480-Rads + GPU-Blocks + Gelid Extreme
    Roccat Isku | Logitech G13 | XBox 360 Controller wired | Logitech Dual Action GamePad
    Roccat Pure Military Dessert Strike | Shogun Bros. Ballista MK-1 | Cyborg R.A.T. 7 Infection
    ADSL2+ ~15MBit/s DL | ~1MBit/s UL
    - Logitech Extreme 3D Pro Joystick
    - Plantronics GameCom Commander Headset
    - Logitech X-210 Speakers
    - Roccat Taito Mid-Size 5mm
    - PC-Master-Race MousePad (yellow)
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    High Definiton Audio Device
    Generic
    1366x768
    Samsung 850 Pro 256GB
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
    Custom-Build
    Asus P8Z77-V
    Corsair AX1200i
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    Generic
    1366x768
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
Tried but my bios can only change date and time and a couple hard drive boot order options. Where is such option for intel speed step and C1E? I dug through my bios for hours finding no such options :(
Throttlestop gave me unsupported/unrecognized CPU and it closed without letting me do anything
and the unpark core app doesnt show anything in when i search registry nothing to unpark or even see listed.
    Acer Aspire XC-603G
    4GB DDR3 1333Mhz
    Intel HD Graphics
    HP Display
    500GB HDD
    Stock/unknown
    Stock/unknown
    Stock
    Logitech Wireless
    Acer USB Mouse
    Unknown//NA
In some MB, the intel speed step is called EIST. Some low end MB will not have C1E feature, so you are stuck.
    Home Brewed
    MSI-Z97
    Dual HP-W2408
    1920X1200
    Antec 850W
    Antec 1200
    Danger Den H20
    Logitech
    35/12mbps
so no way? i'm just stuck at a dead end forever? that really stinks. i can find intel speed step but the C1E is nowhere to be found
    Acer Aspire XC-603G
    4GB DDR3 1333Mhz
    Intel HD Graphics
    HP Display
    500GB HDD
    Stock/unknown
    Stock/unknown
    Stock
    Logitech Wireless
    Acer USB Mouse
    Unknown//NA
Just open "run" in start, type in "regedit", go to 2 places :
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\intelppm]
[HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\services\Processor]
change in both places variable "Start" value from 3 to 4 and restart pc. That will make run your cpu at full speed all the time. You will have some warning triangles in device manager near cpu cores, but thats ok, that what we did - completely disabled cpu speed control. It is safe procedure, i am also using this tweak.
    7 x64
Your CPU has burst technology and not Turbo boost, that may be the reason your CPU is not supported by Throttlestop.
    Win 8.1
    Acer Aspire E1-571
    i5-3230m
    Acer Type-2
    8GB DDR3 1333MHz
    Intel HD 4000
    Generic
    1366x768
    Generic
    QWERTY
    ELANTECH Touchpad
    12.68Mbps
    IE11
This isn't a problem that is going to be caused by your cpu throttling up and down. We have lots of Core2Duo's at work that fluctuate from 800Mhz and 2.4Ghz and these things run smooth as butter with web pages The ability to scale up and down the CPU happens instantly.
    Windows 7
    Self-Built in July 2009
    23" Acer x233H
    Intel X25-M 80GB Gen 2 SSD
    Corsair 620HX modular
    Antec P182
    stock
    ABS M1 Mechanical
    Logitech G9 Laser Mouse
    15/2 cable modem
Trying the registry fix will report back on reboot if it works!
Edit: back and now my CPU was always at 1.99Ghz instead of 2.41ghz so i reverted back the change now sometimes it idles at 2.0Ghz and under a small load above 9% it goes somewhere up to 2.41Ghz but i want it to always stay at 2.41Ghz without having to run a CPU load program all the time? is there some way to make a program similar to system idle process but that keeps it at 100% without an actual large CPU load? like very very low CPU time? i know it would work but would be silly running constantly just to keep it at 2.41Ghz instead of 2.00Ghz
so is there a software or bios option that will let me always keep the Intel Burst Frequency technology feature enabled to 2.41Ghz 100% of the time? i have no overheating issues that i can see whether gaming or general tasks
    Acer Aspire XC-603G
    4GB DDR3 1333Mhz
    Intel HD Graphics
    HP Display
    500GB HDD
    Stock/unknown
    Stock/unknown
    Stock
    Logitech Wireless
    Acer USB Mouse
    Unknown//NA
what about for intel celeron n2840? i got same problem, as i don't want this burst frequency anymore, it's going to destroy my pc i fear
    Acer
    Intel Celeron N2840
    4.0 GB DDR3
    Chrome
    Avast!
