Solved using my cpu without thermal paste totally no (Fan) too
Gamer11
Closed as requested
My cpu was running just fine normal use 44C full load 51-54C
suddenly the normal became 49C and full load 69-72C the temps started to raise in summer
seems the junk Fan its horrible any ways it makes noise only
can you believe? this cpu was running without the fan for +5 months
Why? because When I checked this fan it has poor quality and junk noisy fan
removed it the thermal paste was thick and drying this fan is totally torned (not touching the cpu) : looks like all this period my thermal paste and CPU was doing
the job turned the computer on without any fan cpu pushed to OS running at normal at 49C so what//
this fan looks like have bent metal not stable on the cpu any ways I put it until I get new one now
I underclocked to 1200mhz to save the cpu at 44 idle 49 load totally the fan is doing nothing
so what I keep my eyes on the temp until I replace this fan it
    Win 10 Enterprise X64
    Gamer11
    Intel Core i7 5930k
    ASUS X99 Deluxe
    4x4 G.skill DDR4 2133mhz
    GTX 780 Ti GHZ
    WD 2TB
    EVO 840
    Corsair 850w
    NZXT switch 630
    Corsair H110
    Avira
Why not replace the whole heatsink-fan-combo ? There are some not so expensive ones on the market.
    Windows-10-Pro-Build-11099.rs1-x64
    Custom-Build
    Intel Core i7 3770k @4800MHz
    Asus P8Z77-V
    G.Skill 16G(4*4G) DDR3-2400 Quad Channel [TDX] F3-2400C10Q-16GTX
    2x Gigabyte GTX980-Ti-OC-STRIX-6GB in 2-Way-SLI (1408MHz | Boost: 1544MHz | Memory-Clock: 8000MHz)
    OnBoard Realtek® ALC892 8-Channel High Definition Audio
    Asus VE278Q 27" Wide Led Black Full HD 2ms | Dell S2409W 24" 5ms
    - Intel 520S 240GB/SATA3/R 550MBs,W 520MBs/25nm/3.5"Kit/5yr
    - Samsung 840 EVO SATA3 500GB
    - Seagate Barracuda SATA3 1TB 7200RPM 64mb Cache
    - Seagate Constellation SATA3 3TB 7200RPM 64mb Cache
    Corsair AX1200i
    Thermaltake Level-10 GT LCS
    EK H3O HFX 240mm Liquid Cooling Kit + 2x EK-480-Rads + GPU-Blocks + Gelid Extreme
    Roccat Isku | Logitech G13 | XBox 360 Controller wired | Logitech Dual Action GamePad
    Roccat Pure Military Dessert Strike | Shogun Bros. Ballista MK-1 | Cyborg R.A.T. 7 Infection
    ADSL2+ ~15MBit/s DL | ~1MBit/s UL
    - Logitech Extreme 3D Pro Joystick
    - Plantronics GameCom Commander Headset
    - Logitech X-210 Speakers
    - Roccat Taito Mid-Size 5mm
    - PC-Master-Race MousePad (yellow)
Do you mean whole cooler is doing NOTHING at all ????? You had it overclocked to 3.7GHz with a standard, factory cooler and complain about fan noise ???
If it's so, its a wander it did not burn up by now. That needs to be fixed pronto !!!
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
its not even the factory cooler it looks like it but has torned metal all this period and not touching the cpu
for the noise i did not mean it totally but its useless all it do is make noise that what I meant
yup pretty cool chip
95%
    Gamer11
    Intel Core i7 5930k
    ASUS X99 Deluxe
    GTX 780 Ti GHZ
    WD 2TB
    EVO 840
    Corsair 850w
    NZXT switch 630
    Corsair H110
    Avira
No If I had its stock cooler it would be much better I know this chip (easily 3.7GHZ) 56 Full load with the stock cooler ::
    Gamer11
    Intel Core i7 5930k
    ASUS X99 Deluxe
    GTX 780 Ti GHZ
    WD 2TB
    EVO 840
    Corsair 850w
    NZXT switch 630
    Corsair H110
    Avira
I am in an area which the strongest cpu in it is Pentium 4 :) they are all junk so I need to go to the capital but I dont have time
and I took +2 months to look for 4930k ;; looking for someone abroad look at i7 4930k vs Pentium 4
    Gamer11
    Intel Core i7 5930k
    ASUS X99 Deluxe
    GTX 780 Ti GHZ
    WD 2TB
    EVO 840
    Corsair 850w
    NZXT switch 630
    Corsair H110
    Avira
That's no fun then. Let's hope you get it fixed / replaced before it dies.
:shock:
    Custom-Build
    Asus P8Z77-V
    Corsair AX1200i
:shock:
I will Thanks I was not funny at this :shock:
    Gamer11
    Intel Core i7 5930k
    ASUS X99 Deluxe
    GTX 780 Ti GHZ
    WD 2TB
    EVO 840
    Corsair 850w
    NZXT switch 630
    Corsair H110
    Avira
:shock:
I believe you and it's for sure quite a pain in the butt.
I have similar trouble here in Australia with certain things as well, but not only computer stuff.
It was like stepping in a complete different world, when I moved in 2008 from Germany to Australia and I'm still trying to adjust.
    Custom-Build
    Asus P8Z77-V
    Corsair AX1200i
Jeez, and I thought it was tough in my country. What about mail order, can you get anything like that. I haven't seen inside of a computer store for 3 or 4 years. I get my stuff thru internet orders, new or second hand and all of it on local level.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
:shock:
hard thing I was asking about the i7 4930k with 2011 motherboard
all people said you are wrong the cpu is 1755 socket :eek:
I said what 1755 based motherboard ?? I never heard about this socket it even not exists
and asked about the GTX 780 Ti he claimed that it has 4GB of memory
all sorts of things is wrong because all people buy things like Core 2 duo or 1.8 dual cores (intergrated GPUS)
he has no idea about GTX 660 To Titan
so If I need any thing I must go and locate it and buy it
I never tried ordering online before but thanks good idea
he refused to buy the 4930k claiming that it needs 1755 socket /??
    Gamer11
    Intel Core i7 5930k
    ASUS X99 Deluxe
    GTX 780 Ti GHZ
    WD 2TB
    EVO 840
    Corsair 850w
    NZXT switch 630
    Corsair H110
    Avira
its running in real time at 45C only at 1200mhz but no lag or something like that
can still run HD videos well too
    Gamer11
    Intel Core i7 5930k
    ASUS X99 Deluxe
    GTX 780 Ti GHZ
    WD 2TB
    EVO 840
    Corsair 850w
    NZXT switch 630
    Corsair H110
    Avira
It's still a risk, you never know when some power spike or something can get stuck. Luckily processors slow down or shut off when overheated. If it was an older 4462 Athlon you would be sending smoke signals by now.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
thanks I will get a cooler as soon as possible
luckily It is a good chip it has excellent performance
what is your opinion about people saying 4930k uses 1755 socket ;;:roflmao:
    Gamer11
    Intel Core i7 5930k
    ASUS X99 Deluxe
    GTX 780 Ti GHZ
    WD 2TB
    EVO 840
    Corsair 850w
    NZXT switch 630
    Corsair H110
    Avira
As far as I remember socket 1755 is for certain Xeon processors and 4930K is 2011.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
so If I wanted something I need to go my self and buy it
Thanks for all your help
    Gamer11
    Intel Core i7 5930k
    ASUS X99 Deluxe
    GTX 780 Ti GHZ
    WD 2TB
    EVO 840
    Corsair 850w
    NZXT switch 630
    Corsair H110
    Avira
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
    Gamer11
    Intel Core i7 5930k
    ASUS X99 Deluxe
    GTX 780 Ti GHZ
    WD 2TB
    EVO 840
    Corsair 850w
    NZXT switch 630
    Corsair H110
    Avira
In my 25 years of build and repairing PC's, in the past 10 years or so, I have never seen a CPU "burn up" for any reason. The modern CPU's have a thermal overload built in so if the temps exceed the mas temp allowed, the CPU will simply shut down and not boot up again until it cools down. I don't recommend testing this on a CPU that you need because I don't know what the long term results of such "stress testing" on the CPU would be but CPU's do not simply "burn up" like they used to many years ago.... I hooked up a Q6600 CPU yesterday and forgot to plug in the cPU fan to the motherboard and it booted into the BIOS then ran for a minute or two then shut down. No harm done...
    Win 10 Pro 64bit
    Corsair M65 wired
    85MBps DSL
    Chrome and Edge
    1GBps Ethernet ports
Actually I can hear of very small number of processors dieing at all. Every now or then some gets burned by too high voltage during extreme OC or carelessness. With safeties built into them and MB they seem to be outlasting everything else in the computers. Most vulnerable are video cards, it seams. Nevertheless, I would not play with stuff like heat, some damage does occur every time it's safeties kick in, be it heat or voltage and that may cause problems in the whole machine down the line.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
