Deathly buzzing sound and possible CPU issues
  1. #11
    windows 8.1
    Hey guys, update. I spoke with acer support. I did a system refresh which wiped the programs but not most documents. The audio issue remained. I downloaded the audio drivers again from acers website and it seemed to go away.
    Unfortunately the issue came back a couple times this week-I tried disabling non microsoft services on start up, it seems to have gone. It popped up again today and seems to have gone after I restarted. I feel like there's some shitty program or something that's causing this...I don't know what.
    I also find this warning in the event viewer, I don't know if it is related or not.
    "The speed of processor x in group 0 is being limited by system firmware. The processor has been in this reduced performance state for 71 seconds since the last report." where x is 1-4 for each processor. Should I make a new topic for this? I tried doing some research, I have all my battery settings to max performance, I don't know what is screwing with my processors.
    I will keep you guys updated, hopefully I can isolate the cause of this damn thing. In the meanwhile do you guys have any methods for detecting hardware issues? I want to make sure it's not a hardware problem. Thanks.
    Quote Originally Posted by Peter2 View Post
    Thank you for telling us you would keep us updated. This how we, or at least I, learn.
    I agree, its pointless to just leave and not even tell people what worked, nobody learns.
  2. #12
    Windows 10 Pro x 64
    hardware dx
    Hello Theridon
    "do you guys have any methods for detecting hardware issues? I want to make sure it's not a hardware problem. Thanks."
    >When you boot tapping F12 or UEFI , do you see any word "diagnostics" along with boot choices.
    My pc and some do. When you click it you can run a dx of all your hardware. Also, if you don't have this internally, go to the pc manufacturer and find the hardware diagnostic program. On some pcs there is either in the F2 Bios area or another key like F8 where you may find a diagnostic program. I installed mine from the manufacturer but b/c I have one internally, I removed the one from them.
    Mine takes about 20 minutes and then asks if I want a complete dx of my hardware.
    Good luck and let us know.
    P.S. If all else fails, do a search of Acer program to test hardware.
Page 2 of 2 FirstFirst 12
Windows 8.1 freeze with buzzing sound
Hello! I have an Acer Aspire 5750G laptop (Intel i5-2410M, 4GB DDR3 RAM, GeForce GT540M 1GB, 640GB HDD) with Windows 8.1 Pro 64bit on it. Sometimes (well, recently alot of times) it freezes completely with a sound buzz (if there was any sound playing at the moment). It happened while browsing...
Performance & Maintenance
Noise/Buzzing Heard in Headphones when Sound Unmuted
Hi everyone, I have an interesting problem: On my laptop (Lenovo Y510p) I can hear a buzzing/whistling/noise sound while my headphones are plugged in. The problem goes away when I mute my sound, but this buzzing can be heard while booting as well. This led me to believe that my problem is...
Constant buzzing sound with Asus xonar d2x
Hey, yesterday I went from windows 7 to windows 8, everytime I close a game or a program with sound, this buzzing noise comes, and it wont stop until I restart my PC. Might be worth mentioning that the drivers are beta drivers, but they have been since 2012, so the shouldnt be a problem. And yes I...
Sound Card Issues
Every 5 days or so, my sound card will have a bad day, and all noise coming through my headset will be distorted and static-like. Usually restarting my computer will fix it, but today it stopped working altogether. I check the computer, and it says that no headphones or audio are plugged in. I...
buzzing sound and some lag
I need help ,some times I get this low buzzing sound in windows 8 while playing audio/video files and while gaming , It only happens for a couple of seconds , 2-4 seconds and then everything goes back to normal . this happens a lot of times . I'm using windows 8 pro 64 bit running the os...
Sound issues
As of recently, I have noticed my sound will randomly just stop. There's first a brief half-second of a static-like crackling and then a few "pop" noises. It will then stay muted for anywhere between a few seconds to several minutes. However, using my Creative software (either Creative Console...
Sound Blaster X-FI MB issues
