Need help making uTorrent lower priority than browsing
    I am running uTorrent and my daughter (and I) are finding that when the torrents are running the browsers are slow.
    I am wondering whether there is a setting in uTorrent that I haven't been able to find (I have looked - promise!) that makes uTorrent take a lower priority for bandwidth than anything else going on.
    If I'm not wrong, I could go to each torrent and mark it a low priority (this would work, no?), but there are quite a few running and I would like to have this as a permanent setting.
    I'd be very greatful if anyone could help with this, and I'm sure my daughter will be too!
    Windows 8.1 Pro X64
    You could try adjusting the Bandwidth settings.
    Thanks Ztruker and Hairy Scot...
    Hairy - if I'm not wrong, lowering the bandwidth settings in uTorrent will cap the speed all the time, whereas I want it to be basically an open throttle for uTorrent when the system is not otherwise being used. Is that right? If so, it's not what I wanted to achieve.
    Ztruker - As I understand it, lowering the priorities on my computer will only work locally, won't it? Will it still give priority to my daughter using the computer in her room? How will the uTorrent running on my computer know when my daughter is using the computer in her room on the WiFi?
    My daughter's at Uni, so it's really important that I can get this sorted out as much of her work is done online. I know I can just run the torrents overnight only, but, I'm sure there's a way to do this.
    I'm thinking maybe it needs to be done through my modem???
    If it helps, the modem is NetComm NB604N
    Thanks, again
    windows 8.1
    the latest version of utorrent is a pile of crap, use an older version or another client
    Windows 8.1 Pro X64
    You could check how to set up and implement QoS on your modem/router.
    WiFi connections are very much slower than cable so it may also be worth looking at providing a cable connection to your daughter's PC.
need help with utorrent in windows 8.1
i have windows 8.1 and cant stand it! i downloaded "startmenu8" becuz i dont like dealing with the barney-like tiles...i downloaded utorrent and just recently was able to download files from sites like kickass, etc and watch movies....but somehow (thru virus or my own computer illiteracy) i am no...
Software and Apps
Your resolution is lower than...
After connecting my new laptop to the my 30" tv with an HDMI cord and then removing it later, the resolution was messed up. I received a notification bubble saying that my resolution was at the recommended settings. I went to my screen resolution settings and the slider said it was at 1366x768...
Graphic Cards
BSOD while using utorrent!
I am having problems with my laptop, it is crashing again and again whenever i am using utorrent! A blue screen comes and then the windows restart! I followed option 2 in your BSOD instructions and i have attached the file with this. Please help asap!
BSOD Crashes and Debugging
BSOD using uTorrent
Hello, I need help with my PC. My PC keeps crashing and as far as I remember it happens while I'm using uTorrent, but I don't know for sure. I'm using Windows 8 64 bit and I attached my SF file. Thank You
browsing is slow or impossible while using utorrent
Hi, I am a bit of a newbie to uTorrent. As it says in the thread subject I am experiencing that when downloading with uTorrent the general browsing is either very slow or impossible (page not responsive). I have recently found a thread that suggests a few tweaks that could help, I have...
Browsers & Mail
Hard drive just keeps running lower and lower on space
About 1-2 weeks ago, I had 15GB of space left on my SSD that is solely committed to OS and drivers. Today, I have 2.9GB left. I have downloaded nothing, and I have changed nothing. What is going on? Any programs to help me take a closer look at why my SSD space is disappearing? I've had this OS for...
Performance & Maintenance
uTorrent for Metro UI
Does anyone know how to use utorrent metro app. It asks me to add server, to type some IP adress and port. Can anyone post some example for working server. Thanks 13146
Software and Apps
