Need help making uTorrent lower priority than browsing
Boolean Chants
Hi :)
I am running uTorrent and my daughter (and I) are finding that when the torrents are running the browsers are slow.
I am wondering whether there is a setting in uTorrent that I haven't been able to find (I have looked - promise!) that makes uTorrent take a lower priority for bandwidth than anything else going on.
If I'm not wrong, I could go to each torrent and mark it a low priority (this would work, no?), but there are quite a few running and I would like to have this as a permanent setting.
I'd be very greatful if anyone could help with this, and I'm sure my daughter will be too!
Thanks...
BC
    Intel Cor i7-4770
    16Gb RAM
    Windows 10 Pro X64
    Lenovo IdeaCenter K450
    Lenovo
    Intel Integrated HD Graphics
    Realtek HD Audio
    HP h2207
    1680x1050@59Hz
    250GB Samsung EVO SATA-3 SSD;
    500W
    Wired USB
    Wired USB
    3GB Up, 30GB Down
    SeaMonkey
    Windows Defender; MBAM Pro
    UEFI/GPT
    PLDS DVD-RW DH16AERSH
You could try adjusting the Bandwidth settings.
    Windows 8.1 Pro X64
    Gigabyte Technology Co., Ltd. GA-B75M-D2V
    Intel(R) Core(TM) i5-3470 CPU @ 3.20GHz, 3601 Mhz, 4 Core(s)
    8 GB DDR3 1600MHZ
    GE Force GT 610
    Onboard Realtek High Def
    Dell U2913WMP
    2560x1080
    Western Digital WD10EZEX-00RKKA0 1TB
    Seagate ST2000DL003-9VT166 2TB
    Seagate ST31000528AS 1TB
Thanks Ztruker and Hairy Scot...
Hairy - if I'm not wrong, lowering the bandwidth settings in uTorrent will cap the speed all the time, whereas I want it to be basically an open throttle for uTorrent when the system is not otherwise being used. Is that right? If so, it's not what I wanted to achieve.
Ztruker - As I understand it, lowering the priorities on my computer will only work locally, won't it? Will it still give priority to my daughter using the computer in her room? How will the uTorrent running on my computer know when my daughter is using the computer in her room on the WiFi?
My daughter's at Uni, so it's really important that I can get this sorted out as much of her work is done online. I know I can just run the torrents overnight only, but, I'm sure there's a way to do this.
I'm thinking maybe it needs to be done through my modem???
If it helps, the modem is NetComm NB604N
Thanks, again :)
BC
    Intel Cor i7-4770
    16Gb RAM
the latest version of utorrent is a pile of crap, use an older version or another client
    windows 10
    Dell
    12GB
@BC
You could check how to set up and implement QoS on your modem/router.
WiFi connections are very much slower than cable so it may also be worth looking at providing a cable connection to your daughter's PC.
    Windows 8.1 Pro X64
    8 GB DDR3 1600MHZ
    GE Force GT 610
    Dell U2913WMP
    2560x1080
