Stuck in Automatic Repair loop, System Restore not working
    IE 9
    My Toshiba laptop/Windows 8.1 installed a VLC Media player & Malware bytes today. I was instructed to Restart as 'drivers not working properly' & since then have been on the Automatic Repair loop. It says it cannot fix it - log file: C:\WINDOWS\System32\Logfiles\Srt\SrtTrail.txt, & I tried a few System Restore points but that just says -
    System Restore could not access a file. This is probably because an anti-virus program is running on the computer . Temporarily disable your antivirus program and retry System Restore. You can try System Restore again If you continue to see this error, you can try an advanced recovery method.
    Thing is I can't get into Windows or my laptop to disable the antivirus program. I'm not very techy so could someone please help me to get back into Windows.
    I don't have any CD or DVD & no product key as the disc has been misplaced.
    ME, XP,Vista,Win7,Win8,Win8.1
    Welcome to EightForums
    Have you made the OEM manufacturer's Recovery Disks?
    We always assume you have made your Recovery Disks using the OEM manufacturer's Recovery Media Creator app the first day you had your new PC.
    & made the Startup Repair CD. (Windows 8 only)
    Recovery Drive - Create with USB Flash Drive in Windows 8
    System Repair Disc - Create in Windows 8 (Windows 8 only)
    I would recommend you making the OEM manufacturer's Recovery DVD's or USB drive.
    How to make Toshiba Recovery disks.
    Toshiba How-To: Create System Recovery Media DVDs on a Windows 8 Laptop - YouTube
    Toshiba How-To: Understanding Windows 8 system recovery options - YouTube
    Creating Recovery Media for Windows 8 - TOSHIBA FORUMS
    You can order the Microsoft official OEM Recovery disks from the OEM manufacturer's website.
    Toshiba Service Portal - Laptop Recovery Media Services - Toshiba
    From the Repair CD/USB: (or the Toshiba Recovery disk)
    How to do a Auto Repair:
    Automatic Repair - Run in Windows 8
    Note: You may need to do startup repair 3 to 4 times.
    Startup Repair - Run 3 Separate Times - Windows 7 Help Forums
    How to do a System Restore:
    System Restore - How to Do in Windows 8
    IE 9
    Thanks for your reply. I don't have the recovery discs or any DVD's. I ended up resetting my computer
    You can try to disable early launch of antivirus in advanced options
1st Automatic Repair Loop & now stuck at "Please wait"....
Looking a for some guidance here. I have a Toshiba Satellite C55t-A5222 laptop that went into the dreaded "Automatic Repair Loop". I attempted to boot in Safe Mode to go from there. Upon rebooting (in Safe Mode), my laptop remained at the "Please wait" screen with the spinning dots for hours. ...
Stuck in automatic repair loop, can't start.
Hi guys, I'm having an issue with my 8.1 on my desktop PC. Have had 8.1 installed for a couple of months now without issue until recently. Computer will not start, ending on a sad smiley face BSOD with the message INACCESSIBLE_BOOT_DEVICE. Error codes 0x80070571 and 0xc0000001 have been...
BSOD Crashes and Debugging
Automatic repair loop; Recovery options not working
Hi all, Recently was running a backup program and suddenly I get the Windows 8 blue error screen (the one with the mocking ':(' icon) and system dies. I turn on and it seems to booting very slowly then it proceeds to do the pre login screen installation of updates. After half an hour or so and...
Stuck in Automatic repair loop. refresh/restore wont work
Hi. I accidentally removed a usb cable from a powered usb hub , and a volume slider of some other program appeared superimposed and floating above my music making program , so I restarted the pc. From then on , it wouldnt start , and kept saying preparing automatic repair, then reached 40% and...
Stuck in the 'Automatic Repair' loop
Stuck in the 'Automatic Repair' loop! Tried sfc with the offbootdir & offwindir options & get the reply that it's found things wrong, but can't fix them.
HELP! Stuck at automatic repair loop... WONT BOOT.
I am having this issue where my laptop with windows 8 just won't boot. I see my acer splash screen, then I see a blinking _ then it goes blank for around 20 min, and then it would say "automatic repair, diagnosing" I've waited nearly 20 hours, almost an entire day leaving my computer on, just still...
