New System Slower than Old System
Tomel
Virginia
I recently built my first rig, one that should be pretty fast. However, things load slower than my 4 year old system with less impressive specs. Also, at times, something must occasionally be using a lot of cpu cycles since my keystrokes are not recognized for maybe 3-5 seconds and then the display catches up. I've looked at my running processes and can't find anything that stands out as odd. While I'm not a technical expert, I have enough experience with hardware, Windows and common apps that I rarely run into a problem I can't solve. I would like any suggestions anyone has to get to the bottom of my problem. By the way, these issues have been present since I first turned on the system and installed Windows and I'm extremely careful about downloading questionable apps from questionable sites.
Here are the major system specs.
Asus Z87-PRO ATX LGA1150 Motherboard
Intel Core i7-4771 3.5GHz Quad-Core Processor
G.SKILL Ripjaws X 16GB (2 x 8GB) 240-Pin DDR3 1600 (PC3 12800) / F3-12800CL10D-16GBXL
Samsung 840 EVO 250GB 2.5" SSD
Western Digital BLACK 1TB 3.5" 7200RPM / WD1003FZEX
Asus GeForce GTX 650 Ti 1GB / GTX650TI-O-1GD5
I'm running Avast Free and Malwarebytes. I don't using any off-the-wall or uncommon apps. I have used Black Viper guidelines to shut down unused services. My only enabled start-up files are as follows:
"C:\Program Files (x86)\Google\Chrome\Application\chrome.exe" --type=service
"C:\Program Files\AVAST Software\Avast\AvastUI.exe" /nogui
"C:\Program Files (x86)\EMET 4.1\EMET_agent.exe"
"C:\Program Files\Realtek\Audio\HDA\RAVBg64.exe" /DTSU2P
"C:\Program Files\Realtek\Audio\HDA\RtkNGUI64.exe" -s
Any suggestions? I'd like to be able to take a look at what's happening when, for example, my keystrokes are not recognized immediately, but not sure how to accomplish that. I've tried quickly looking at task manager, but the duration of the problem is too short.
Thanks in advance for any ideas.
    Custom Home Built
    Intel i7-4771
    ASUS Z87-Pro
    16 Gb
    ASUS GeForce GTX 650 Ti 1GB
    None
    Acer T232HL
    Primary - Samsung 840 EVO 250 Gb
    Secondary - Western Digital BLACK 1TB
    Corsair RM 650W 80+
    Fractal Design Arc Midi R2
    Cooler Master Hyper 212 EVO
    Logitech MK520
    Logitech MK520
    FiOS-15Mb
    IE11 / Firefox
    Avast Free
Wired keyboard or wireless ?
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    Asus strix 570 OC 4gb
    Samsung 960 evo 250GB
    Silicon Power V70 240GB SSD
    WD 1 TB Blue
    WD 2 TB Blue
    Bunch of backup HDDs.
    Sharkoon, Silent Storm 660W
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
Wireless keyboard & mouse.
    Custom Home Built
    Intel i7-4771
    ASUS Z87-Pro
    16 Gb
    None
    Acer T232HL
    Corsair RM 650W 80+
    Logitech MK520
    Logitech MK520
    FiOS-15Mb
    IE11 / Firefox
    Avast Free
Might have some communication problems between KB/Mouse and rest of the system, specially if it is WiFi type. I would first check with a wired KB and drivers for wireless ones.
    Home made
    AMD Ryzen7 2700x
    Asus Prime x470 Pro
    16GB Kingston 3600
    WD 1 TB Blue
    WD 2 TB Blue
    Raidmax
    CCM Nepton 140xl
    40/2 Mbps
    WD
