System restore could not start
  1. #11
    Windows 8.0 x64
    It hasn't been determined that av scan cannot be accessed. I'm waiting for response from the OP. For a corporate environment it may be fine to wipe everything at first blush since you have standard setups. Every machine installs from the network image the same. But for the individual user a panic backup and reinstall might not be the best course. Often what was done to customize or get and application to work correctly isn't kept in a log. It's a user not an IT guy.
  2. #12
    Quote Originally Posted by Jaynik View Post
    Fair call but i dont wait till my complete system is damaged and BIOS/cache is infected.. from experience if a indows tool is affected and anti virus is not access able, so if you want to do system scans try HDD regenerator, disk check and like i said live boot virus check... all these will take longer then creating an iage and reinstall of Windows and set up system right so you have a reduced risk, also imaging with incremental backups will ensure an intrusion can be fixed fast.. If you cant access anti virus, malware bytes and system restore either HDD is damaged with sector errors etc or Windows is corrupt... although format is as you say radical i bet thats the end result... anywho i offer help in peace and hope you sort it out.... id be using Hirens etc to test HDD for sector errors and attempt to create image just in case HDD is on its way out...
    I agree about having the clean system image handy to restore the system from but do you really believe that we here at this forum aren't already aware of every single thing you are saying here?
    Needless to say this system is most likely past the point of no return and it's certainly too late to perform a system image back up. I also highly doubt the harddrive is the problem.
    I might think about performing a system file scan or a DISM repair scan but with the A/V's unable to run I'd say this system is already pretty messed up which is typical by the time they get here.
  3. #13
    Agreed and i do apologise my friend if i came across different from intended, my brain goes into fix mode and blah... i supported Dentists, lawyers, Foodland and other major businesses where we had backups ready and dint have time to question, replace HDD restore image and test when business is closed.. and yes it does sound like its life is at its end..
Page 2 of 2 FirstFirst 12
System restore not creating restore point
I went into Task Scheduler and set System Restore to create a restore point every day at 12:01am. Under Conditions I cleared all the check boxes because I want SR to run regardless of whether computer is idle or not. I have been watching this for about 1 week and so far it's not created a single...
Performance & Maintenance
System Restore will not restore
I make manual System Restore points and when I try to use them to restore, it goes thru the motions but ends up saying System was not restored - returned to previous state. I make Macrium Reflect back-ups regularly and they work great - no problems. So, what I have done is turn off System...
System Restore from W8 Install disk for a W8.1 System?
Dumb question - if I panic and have to do a system restore or system reset using the install DVD for W8 what will happen to the W8.1 version I just downloaded and installed?
System Restore and System Refresh not working completely!
Hello to all, A month back I accidentally deleted the wow6432 node from my registry under system_user. I believe this is the root of all my problems. Once I did that, my toshiba c885 D 64 bit would not boot. I forced the computer to shut down and pressed f12 to get to the system recovery...
Automatic restore points is not working in system restore
Automatic Restore Points is not working in System Restore. Task Scheduler is empty during last 30 days.
System image restore & system repair disc problems
I recently had to return my HP Pavilion g7 Windows 8 64- bit only laptop to the manufacturer for repair under warranty. Prior to this I created a system image as the Hard Disc was going to be replaced. Having now received the repaired laptop I have been trying to restore the saved image. I watched...
how do I start system restore in windows8
How do I start system restore in windows8 I cant even find it.:dinesh:
