Using Advanced System Care
    I Wanted some insight and opinions on using a cleaning program on Windows 8.1. I have been using Advanced System Care for over 5 years on my other computers and it has been a asset.
    I have a new laptop and debating on using "Advanced" on the new Windows.
    Opinions are greatly appreciated and thanks in advance.
    Harrisonburg, Va.
    Try it & see if it works. {Opinion}
    Don't (opinion).
    Windows 10 Pro Prieview x64
    Don't (opinion).
    You don't need it. Get malwarebytes and use whatever anti-virus you like. I use defender which is built into Windows.
    You don't need a defragmenter or a registry cleaner or any of the other programs it downloads.
    Great feedback....
    Thank you, I appreciate the feedback! Have a great day~
    Yep, adamf is correct...
Anyone care to be my hero? Context Menu woes!
I have a few entries which are the last of what im held up on. If i can sort these last 3 entries, I can be on my way to enjoying/using my pc! I need to find the means to REMOVE the BURN TO DISC option from the context menu which appears when right clicking on my E: drive as I dont intend to...
Advanced System Properties - Add to "This PC" Context Menu
Add "Advanced System Properties" to "This PC" and "My Computer" Context Menu in Vista, Windows 7, and Windows 8 This tutorial will show you how to add or remove Advanced System Properties to the "My Computer" (Vista/Windows 7) or "This PC" (Windows 8) context menu for all users in Windows. ...
Advanced IIS question
Hi all. I run a home server with IIS, this serves a commercial web-application on port 80. I also run a code-control server on another port, 1000. This is not HTTP. I have a client with a locked down network; they do not allow traffic to port 1000. Would it be possible to have IIS...
Network & Sharing
Anyone else here care about cable management?
Here is a "before" and "after" picture of a PC that I'm working on for my son's friend. When I see a rat's nest of cables, I assume the person who built or worked on the PC didn't care enough about it to take care of the "details". This was a complete mess, both from a cabling and configuration...
Performance & Maintenance
Any advanced users out there?
Have you tried mounting a wim from bog standard winre? Give it a go and see if you can get it work. I have thrown together ( very quickly) a little first attempt at pe. Quite a bit of effort to overcome the extra restrictions. Curious issue with the sound.
Software and Apps
Lost my F8 Advanced Boot & System Recovery Options on Dual Boot
On both my Win7/Win8 Dual Boot machines I have now lost both my Advanced Boot Options and System Recovery Options on F8. I cannot boot F8 after BIOS post or after selecting either OS from the Metro-style Boot Menu. I tried running Refresh just now on my deskstop but it didn't reinstall these...
Installation & Setup
