JavaScript is disabled. For a better experience, please enable JavaScript in your browser before proceeding.
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an
alternative browser .
Solved Using Advanced System Care
I Wanted some insight and opinions on using a cleaning program on Windows 8.1. I have been using Advanced System Care for over 5 years on my other computers and it has been a asset.
I have a new laptop and debating on using "Advanced" on the new Windows.
Opinions are greatly appreciated and thanks in advance.
OS
HP Pavilion 17 Notebook PC
Intel(R) Core(TM) i3-4000M CPU @ 2.40GHz
6GB
Intel(R) HD Graphics 4600
Realtek High Definition Audio
17.03 HD Backlit
1600 x 900
HGST HTS541075A9E680
HP Cool Sense Teechnology
Microdoft 4000
Try it & see if it works.
{Opinion}
OS
Gateway
AMD K140
Cores 2
Threads 2
Name AMD K140
Package Socket FT1 BGA
Technology 40nm
Family F
Extended Family 14
Model 2
Extended Model 2
Stepping 0
Revision ON-C0
Instruction
Opera 24.0
Avast Internet Security
OS
Home made
AMD Ryzen7 2700x
Asus Prime x470 Pro
16GB Kingston 3600
Asus strix 570 OC 4gb
Samsung 960 evo 250GB
Silicon Power V70 240GB SSD
WD 1 TB Blue
WD 2 TB Blue
Bunch of backup HDDs.
Sharkoon, Silent Storm 660W
Raidmax
CCM Nepton 140xl
40/2 Mbps
WD
You don't need it. Get
malwarebytes and use whatever anti-virus you like. I use defender which is built into Windows.
You don't need a defragmenter or a registry cleaner or any of the other programs it downloads.
OS
Windows 10 Pro Prieview x64
MacBook Pro Core2Duo
T7600
ATI Radeon X1600
Internal
1440 x 800
40GB
Apple
Apple
Varies
Various
Defender
Great feedback....
Thank you, I appreciate the feedback! Have a great day~
OS
6GB
17.03 HD Backlit
1600 x 900
Microdoft 4000
Moved to ten*****s.com
OS
Win 10 Pro 64bit
Corsair M65 wired
85MBps DSL
Chrome and Edge
1GBps Ethernet ports
