Can't use System Restore, nothing happens when I click it
north
I want to use System Restore because every time I right click in file explorer or on my desktop, they crash (but I'm still able to run other programs normally).
But when I try to start it, nothing happens. In the task manager, under background processes, it lists System Restore as many times as I've clicked on it!
My anti-virus software isn't reacting to anything, though.
I really need to make a system image before I send my laptop in to get a hardware problem fixed, but I don't want to carry this over in the system image once the hardwares fixed...
Hi,
There's no hardware problem.
You'll be best off by removing your current antivirus completely, then setting Windows Firewall and Windows Defender to Automatic and starting them too.
You can use ShellExView and/or Autoruns to figure out why Explorer is crashing.
    7601.18247.x86fre.win7sp1
    Self-built Intel based
    Intel DQ965MT
    Hyundai 2 GB DDR2 @ 333 MHz
    Thermaltake 450W
    Logitech M510
    Optimum Online, fast for US
    Pale Moon
Running this dism & sfc batch file may help.
They take a while to finish.
Dism hangs on 20% for a long time & suddenly finishes.
Sfc may take an hour to finish.
View attachment dism.bat
    Gateway
    AMD K140
    Cores 2
    Threads 2
    Name AMD K140
    Package Socket FT1 BGA
    Technology 40nm
    Family F
    Extended Family 14
    Model 2
    Extended Model 2
    Stepping 0
    Revision ON-C0
    Instruction
    Opera 24.0
    Avast Internet Security
