Backing up system drive after using symbolic link
    I am using EaseUs Todo Backup Home. I relocated the installer folder's files from ssd to hd. Do I need to copy the files back before I do a system backup?
    Windows 8.0 x64
    I would just do the backup same as before and check the output image file size. Unless you added or deleted a lot of stuff, if the link is followed and the files included in the backed, the image size should be pretty close to the last one made before relocating the files. You could probably get a definitive answer how it handles hard links on the EaseUS Forum
    Below is the email I got from EaseUS, so it would appear that my installer folder on my hdd would not be imagieid. Would you agree? I like your Ideal though, it is worth a try. Thanks.
    Our product can only include the files actually existing in selected
    EaseUS Support Team
    EaseUS Customer Support Center:
    Windows 8.0 x64
    That seems conclusive.
User profile cannot be loaded - Symbolic link setup
Hey guys, so i have a custom PC i built in 2013 that was for gaming but since I dont game is being used for work/school stuff. Anyways its uniquely setup because I have 3 harddrive being used in my desktop. Two SSD's: a Samsung 830 128gb and a Samsung 840 120gb / One HDD: WD 3TB drive. How I...
User Accounts and Family Safety
Backing up to the cloud
Hi everyone. This may be a stupid question but instead of making recovery discs to backup your computer, is it possble to do the same thing in the cloud? Thanks in advance
Backing up my System
I can't find an option with which I can keep a backup image of my system drive in a blank DVD so that if something happens to the PC and I can't turn it on then I'll be able to use that disc to recover the C drive. I found a similar option in File History > System Image Backup. But the total...
Performance & Maintenance
Solutions for backing up and restoring system drive
Hi Guys! In few days I will have my new computer with Windows 8.1, and I wonder what solution would be the best for easy backing up and restoring of system drive in the new machine. For last 5 years I've been using Acronis to creat an image of entire partition c: , with windows and all my...
I Need help backing up!
Hello, I am going to reinstall windows 8 but I want to keep some of files. Please help?
Backing up the operating system
Hello everyone, just purchased a SAMSUNG Series 3 NP3530EC laptop running Windows 8. It came without a recovery disc. The laptops that I had in the past allowed you to make a copy of the operating system to DVDs. I can not work out how to do this with the Samsung. Any help will be greatly...
Installation & Setup
Seeking expert advice - guidance on applying Symbolic Link
Hi, Hope somebody can point me in the right direction here. I have successfully relocated my C:\Users folder (but NOT ProgramData) to D:\Users (Kari's excellent tutorial) on clean install and by creating test user profiles verified access to Metro Apps and Store Sign In/Download/Install. I...
