Small C Drive 20 GB .. Help Please
    Hi I have a Samsung Laptop with 20 GB :C Drive and 441 GB Drive ... The C is almost full hence i was trying to move some space to the C. Issue is that each are on two different Disks as displayed by the disk management tool. I would appreciate you help on how to increase the C space ... i tried to free some of the D however i failed to move that space to the Disk where the C is on. Thanks
    Windows 8.0 x64
    If you have many programs installed on C: then this post:
    Moving Program Files folder to another partition
    might be useful. Or you could uninstall then reinstall on the other drive. But if done right the hard link should work fine. I used to move directories on Linux all the time and just make a link so that environment variables etc.. continued to work. In Windows you also need the Registry settings to keep working. They should also follow the link.
    If you have an external USB or other drive you may want to back everything up first.
    Also if your swap file is on C: you could move that to the other drive.
    Also system specs is helpful. Saves asking a bunch of "do you have this?" questions.
    You probably should partition your big drive so that there are 3 partitions. The first where boot files are kept which would be called the system partition (100 MB size) and set as the active partition too. The second should be also a primary partition where you can have Windows and programs installed to, known as the boot partition (200-300 GB in size, as you wish) and the third partition also primary where you can move all the data on it now to be kept.
    When done, you can format the small drive then use it as your temp folder drive and pagefile drive.
    You can do a clone from boot partition and system partition of your current small C drive to the correct partitions on the big drive, when the big drive is ready.
    Acronis Disk Director is good to use for this.
    But, lots also depends on your bios - if it is UEFI or not.
    We can best help advise about it, if interested in doing something like this, if you post a screenshot of your current Disk Management screen.
New computer, c: drive too small, d: drive wrong place?
I have just bought an AIO Asus desktop with 1 Tb of storage. The c: (Windows)drive is allocated 100gb and the d: drive 931gb. I just want to transfer all the data from my old computer. This was pretty much all in the folder c:>Users>Myname, but when I try to transfer it all into the same folder on...
Installation & Setup
Games very small
I recently purchased a new Surface Pro before heading on deployment and downloaded a couple games from All of them seem to have the issue of showing in a very small window in the middle of the the screen surrounded by a large boarder of black. I have yet to figure out how to get these...
small icons in IE 11
This doesn't work in Win 8.1 and IE 11. Internet Explorer - Use Small or Large Icons - Windows 7 Help Forums
Browsers & Mail
Small C Drive
Just recently, I had a hard drive failure and sent my laptop in to Toshiba to have it repaired. The hard drive was replaced, but the C drive, which originally had around 700 GB of disk space, now has 89.9 GB. When the computer was returned, I noticed that there was a new drive named "New Volume (F:...
Small black box
When I am using programs such as Microsoft Office, VisualBasics.Net and even the run part in the start menu (classic shell) I have a small black box that is in place where my small thin cursor should be. The black box is small but also covers some letters making it annoying and in the way, it also...
Web pages too small
I have a 17.3 inch screen and the web pages only take up about half of the screen and are too small to read. I went to the control panel and changed the size to 1.5 but it didn't help. Ant suggestions?
Browsers & Mail
Monitor poblem. Too small
Hello to all. Newbie here. I recently installed a fresh new windows 8 Pro onto a a samsung ssd. Everything is going great except.... I have a 25" HP monitor. The image I have leaves about an inch of unused monitor on the left and right sides and about a half inch on top and bottom. I've tried...
Graphic Cards
